产品名称:
GN-R40CR,GN-T7C,GN-R30C
型 号:
价 格:
0.00
品 牌:
189
takex光电开关GN-R40CR,GN-T7C,GN-R30C现货优价,GN-R40CR光电开关
| Specifications |
Models |
Flying lead |
NPN |
GN-T10CR |
GN-T7C |
GN-M2CR |
GN- R40CR |
GN- R30C |
GN-R7C |
PNP |
GN- T10CRPN |
GN-T7CPN |
GN-M2CRPN |
GN- R40CRPN |
GN- R30CPN |
GN- R7CPN |
Detection |
Through beam |
Polarized retro reflection |
Diffuse reflection |
Range |
10m |
7m |
0.03 to 1.3m *1 |
400mm |
300mm |
70mm |
Mini. Detecting object |
ø6mm Opaque |
200 × 200mm White paper |
10 x 10cm White paper |
Power supply |
12 to 24VDC10%, Ripple 10% Max. |
Current consumption |
Trns. : 22mA (Max.) Rcvr. : 15mA (Max.) |
25mA (Max.) |
Output mode |
Output |
NPN |
Rating : Sink current 100mA (DC30V) Max., Residual voltage 1V Max. |
PNP |
Rating : Source current 100mA (DC30V) Max., Residual voltage 2V Max. |
Operating mode |
Light-on/Dark-on selectable |
Response time |
0.5ms Max. |
Operating angle |
10(Receiver side) |
30(Reflector side) |
Hysteresis |
10%(Max.) |
Light source |
Red LED(700nm) |
Infrared LED(880nm) |
Red LED(640nm) |
Indicators |
- Trns.: Power: (Orange LED)
- Rcvr.: Oprating: (Orange LED)
- Stability: (Green LED)
- Oprating: (Orange LED)
Circuit protection |
Short circuit protection built-in |
Materials |
Case |
Polybutyleneteleftarate |
Lens |
Methacrylic resin |
Cable |
Flying lead type : 2m, Connector type(-J) : M8 4pin |
Weight |
Flying lead |
Trns, Recv 60g each |
60g |
Connector |
Trns, Recv 10g each |
10g | |
