Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú »ù¶÷Ê¿KV-10DR, KV-10DT,KV-E4X
²úÆ·Ãû³Æ£º »ù¶÷Ê¿KV-10DR, KV-10DT,KV-E4X
ÐÍ ºÅ£º KV-10DR, KV-10DT
Æ· ÅÆ£º 497
KEYENCE PLC KV-10DR, KV-10DT,KV-E4X£¬KV-C64XC,KV-8EYT,KV-40AR,KV-1000,KV-3000,KV-5000
KV-10DR ,  KV-10DT
(function(sogouExplorer){ sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location); if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); while(a) { hint.push({"text":a.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 0); } })(window.external.sogouExplorer(window,7));
¹«Ë¾Ãû³Æ£º ÉîÛÚÊд´·áÒÇÆ÷ÒDZíÓÐÏÞ¹«Ë¾
µç »°£º 0755 29796001-806 / Ç®¾ü»Ô
ÊÖ»ú£º 13143436561
µØ Ö·£º ÉîÛÚÊб¦°²¾ÅÇø°×½ð¾ÆµêÉÌÎñ´óÏÃ1001-1002ÊÒ
ÓÊ ±à£º 518052
Ö÷ Ò³£º www.Lansea.net
  • ZCMD25Ê©Ä͵ÂÏÞλ¿ª¹Ø×é¼þ
  • Ê©Ä͵ÂZCMD21ÏÞλ¿ª¹ØÁ㲿¼þ
  • XCM-D2516L3Ê©Ä͵ÂÏÞλ¿ª¹ØÁ㲿¼þ
  • XCM-D2516L1ÏÞλ¿ª¹ØÁ㲿¼þ
  • PanasonicËÉÏÂGD-C1Ë«²ãÖØµþ¼ì²âÆ÷
  • È«ÐÂÔ­×°ËÉϾ۽¹¾µFX-LE2
  • omronÅ·Ä·ÁúW4S1-03B¿É±à³Ì¿ØÖÆÆ÷
  • omronÅ·Ä·ÁúE39-R3²»Ðâ¸ÖÍâ¿ÇСÐ͹âµç´«¸ÐÆ÷
  • OMRONÅ·Ä·ÁúD4E-1D10N ÏÞλ¿ª¹Ø
  • KEYENCE»ù¶÷Ê¿¹âÄ»µçÔ´ÏßGL-RP10P
