Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ioLogik W5340-HSDPA
²úÆ·Ãû³Æ£º ioLogik W5340-HSDPA
ÐÍ ºÅ£º ioLogik W5340-HSDPA
¼ò½é
ioLogik W5340-HSDPA 3GÎÞÏßÔ¶³ÌRTU¿ØÖÆÆ÷ÊǼá¹Ì¡¢½ô´ÕµÄÔ¶³Ì¼à¿Ø ºÍ±¨¾¯ÏµÍ³½â¾ö·½°¸¡£²ÉÓÃioLogik W5340-HSDPA£¬Äã¿É ÒÔ×Ô¶¨Òå·äÎÑÍøÂçÁ¬½Ó²ßÂÔ£¬°üÀ¨³£¿ª£¨Always-On£©ºÍ°´Ðè »½ÐÑ£¨Wake-on-Demand£©£¬Õë¶Ô²»Í¬Ó¦ÓýøÐÐÊý¾ÝËÙÂ浀 ÓÅ»¯£¨ÎÞÏßÍøÂçͨѶ³É±¾Ö÷Ҫȡ¾öÓÚÊý¾ÝͨѶËÙ¶È£©¡£ÓÐÁË MoxaµÄ¡°Active¡±¼¼Êõ£¬Äú¿ÉÒÔ¼õÉÙÒ»°ëµÄ´«Êä³É±¾£¬²¢Í¨¹ý ²»Í¬µÄÍøÂçÁ¬½Ó²ßÂÔÀ´ÓÅ»¯Êý¾Ý´«ÊäµÄ·ÑÓᣠÕâÖÖ½ô´Õ¡¢¿íΡ¢¼á¹ÌµÄ½â¾ö·½°¸ÊÊÓÃÓÚÏÂÁÐÓ¦Óãº
  • Ë®/ÎÛË®´¦Àíϵͳ
  • ¹ã²¥¼°µçÐÅ»úÕ¾¼à¿Ø
  • »ù´¡ÉèÊ©¹ÜÀí
  • ÓÍÆø¡¢ÄÜÔ´¼°½»Í¨ÔËÊä
  • µÆ¹â¼à¿ØÏµÍ³
·äÎÑͨѶ ±ê×¼£ºGSM/GPRS/EDGE/UMTS/HSDPA
Ƶ¶ÎÑ¡Ï
• ÈýƵ¶ÎUMTS/HSDPA 850/1900/2100 MHz
• ËÄÆµ¶ÎGSM/GPRS/EDGE 850/900/1800/1900 MHz
EDGE Multi-slot Class£ºClass 10
EDGE Terminal Device Class£ºClass B
GPRS Multi-slot Class£ºClass 10
GPRS Terminal Device Class£ºClass B
GPRS Coding Schemes£ºCS1 to CS4
·¢É书ÂÊ£º
• GSM900£º2 W
• UMTS/HSDPA£º0.25 W
• EDGE900£º0.5 W
• EDGE1800£º0.4 W
• GSM1800£º1 W
LAN ÒÔÌ«Íø£º1 x 10/100 Mbps, RJ45
±£»¤£º1.5 KVµç´Å¸ôÀë
ЭÒ飺Modbus/TCP, TCP/IP, UDP, DHCP, Bootp, SNMP,
SNTP
´®¿ÚͨѶ ½Ó¿Ú£º1 x RS-232/422/485, Èí¼þ¿ÉÑ¡ (9-pin D-Sub male,
»ò5-contact terminal block)
²¨ÌØÂÊ£º1200, 2400, 4800, 9600, 19200, 38400, 57600,
115200 bps
Ä£ÄâÊäÈë ͨµÀÊýÁ¿£º4·ģÄâÊäÈ룬´ø²î·ÖÊäÈë
½âÎö¶È£º16λ
I/OÀàÐÍ£ºµçѹ/µçÁ÷
ÊäÈ뷶Χ£º0 ~ 10 V, ¡À10 V, ¡À5 V, 0 ~ 20 mA, 4 ~ 20 mA
¾«È·¶È£º
• ¡À0.1% FSR @ 25 ¡ãC
• ¡À0.3% FSR @ -10ºÍ55 ¡ãC
²ÉÑùÂÊ£¨ËùÓÐͨµÀ£©£º100 samples/sec
ÊäÈë×迹£º200K ohms (min.)
ÄÚÖõçÁ÷ÊäÈëµç×裺102 ohms
DI/DOͨµÀ ͨµÀÊýÁ¿£º8·
I/OÀàÐÍ£º
• DI»ò¼ÆÊýÆ÷ (×î´ó900 Hz)
• DO»òÂö³åÊä³ö (×î´ó100 Hz)
Êý×ÖÊäÈë ͨµÀÊýÁ¿£º×î¶à8·£¬source/sink¿ÉÑ¡
´«¸ÐÆ÷ÀàÐÍ£ºNPN/PNP type
I/OÀàÐÍ£ºDI»ò¼ÆÊýÆ÷ (×î´ó900 Hz)
¸É½Úµã£º
• Logic 0£ºshort to GND
• Logic 1£ºopen
ʪ½Úµã£º
¸ôÀë±£»¤£º3K VDC»ò2K Vrms
¼ÆÊýÆ÷/ƵÂÊ£º900 Hz£¬¶Ïµç´æ´¢
Êý×ÖÐźŹýÂ˼ä¸ô£ºÈí¼þ¿ÉÑ¡
¹ýѹ±£»¤£º36 VDC
¶Ïµç¼ÆÊýÆ÷£ºÖ§³Ö¶Ïµç¼ÆÊýÆ÷´æ´¢¹¦ÄÜ
Êý×ÖÊä³ö ͨµÀÊýÁ¿£º×î¶à8·, sink type, 36 VDC, 200 mA
I/OÀàÐÍ£ºDO»òÂö³åÊä³ö (×î´ó100 Hz)
Âö³åÊä³ö¿í¶È/ƵÂÊ£º10 ms/100 Hz
¹ýѹ±£»¤£º45 VDC
¹ýÁ÷ÏÞÖÆ£º600 mA
¹ýιرձ£»¤£º160 ¡ãC
¶î¶¨Êä³öµçÁ÷£ºMax. 200 mA per channel
¸ôÀë±£»¤£º3K VDC »ò 2K Vrms
¼ÌµçÆ÷Êä³ö ͨµÀÊýÁ¿£º2¸öAÐͼ̵çÆ÷Êä³ö£¨³£¿ª£©, 5 A
´¥µãÈÝÁ¿£º5 A @ 30 VDC, 5 A @ 240 VAC, 5 A @ 110
VAC
¸ÐÐÔ¸ºÔØ£º2 A
µç×è¸ºÔØ£º5 A
»÷´©µçѹ£º500 VAC
¼ÌµçÆ÷±ÕºÏ/¶Ï¿ªÊ±¼ä£º10 ms, 5 ms (max.)
³õʼ¾øÔµµç×裺1G min. @ 500 VDC
ʹÓÃÊÙÃü£º100,000 times (Typical)
½Ó´¥µç×裨³õʼֵ£©£º30 milli-ohms (max.)
Âö³åÊä³ö£ºÔڶ¸ºÔØÌõ¼þÏ£¬Ã¿·ÖÖÓ20´Î
µçÔ´ÐèÇó µçÔ´ÊäÈ룺24 VDC nominal, 12 ~ 36 VDC
µçÔ´¹¦ºÄ£º
• GPRS Always On (Communication)£º4.2 W
• GPRS On Demand£º2.8 W
»úÐµÌØÐÔ ³ß´ç£º46.8 x 135 x 105 mm (1.84 x 5.31 x 4.13 in)
ÖØÁ¿£º495 g
¹¤×÷»·¾³ ¹¤×÷ζȣº
±ê×¼Ðͺţº-10 ~ 55 ¡ãC (14 ~ 131 ¡ãF)
¿íÎÂÐͺţº-20 ~ 70 ¡ãC (-4 ~ 158 ¡ãF)
´æ´¢Î¶ȣº-40 ~ 85 ¡ãC (-40 ~ 185 ¡ãF)
¹¤×÷ʪ¶È£º5 ~ 95% (non-condensing)
°²¹æÈÏÖ¤ EMI£ºFCC part 15, CISPR (EN55022) Class A
EMS£ºIEC 61000-4-2 (ESD), levels 2, 3IEC 61000-4-3
(RS), level 2IEC 61000-4-4 (EFT), level 2IEC 61000-4-5
(Surge), level 3IEC 61000-4-6 (CS), level 2IEC 61000-4-
8 (PM), level 1IEC 61000-4-11 (DIP)IEC 61000-6-2 (ESD),
levels 2, 3IEC 61000-6-4 (EFT), level 2
Safety£ºUL508 (Pending)
Shock£ºIEC 60068-2-27
Freefall£ºIEC 60068-2-32
Vibration£ºIEC 60068-2-6
×¢Ò⣺ÇëµÇ½MoxaÍøÕ¾£¬»ñÈ¡×îÐÂÈÏÖ¤ÐÅÏ¢¡£
±£ÐÞ ±£ÐÞÆÚ£º2Äê
¹«Ë¾Ãû³Æ£º Ħɯ¹ú¼ÊóÒ×£¨ÉϺ££©ÓÐÏÞ¹«Ë¾
µç »°£º 021 52589955 / Íõ С ½ã
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÑÓ°²Î÷·1160ºÅÊ×ÐÅÒø¶¼¹ú¼Ê¹ã³¡18²ã
ÓÊ ±à£º 200052
Ö÷ Ò³£º http://www.moxa.com.cn
  • moxa EDR-810ϵÁÐ
  • moxa MD-119ϵÁÐ º£ÊÂרÓÃÏÔʾÆ÷
  • moxa MXview2.3ÍøÂç¹ÜÀíÈí¼þ
  • moxa ioLogik R1241
  • ioLogik R1240
  • moxa ioLogik R1214
  • moxa ioLogik R1212
  • moxa ioLogik R1210
  • moxa IEX-402-VDSL2ϵÁÐ
  • moxa MGate™ 5102-PBM-PNϵÁÐ
