| Output mothod Ý”³öģʽ |
NPN N.O. |
¨C |
¨C |
SN04-N |
SN04-ND |
| NPN N.C. |
¨C |
¨C |
SN04-N2 |
SN04-N2D |
| PNP N.O. |
¨C
¨C |
SN04-P
SN04-PD |
| PNP N.C. |
¨C |
¨C |
SN04-P2 |
SN04-P2D |
NPN N.O./N.C. PNP N.O./N.C. |
¨C |
¨C |
¨C |
¨C |
| SCR N.O. |
SN04-A |
SN04-AD |
¨C |
¨C |
| SCR N.C. |
SN04-A2 |
SN04-A2D |
¨C |
¨C |
| Sensing surface / ™zœy·½Ïò |
Top surface / ǰ·½ |
Top surface / ǰ·½ |
| Standard sensing object / ˜ËœÊ™zœyÎï |
Iron 18 x1 8 x 1mm |
| Sensing distance / ™z³ö¾àëx |
4 mm |
4 mm |
| Secure sensing distance / ½¨×h¾àëx |
0 to 3.2 mm |
0 to 3.2 mm |
| Hysteresis / ßtœþ |
¨Q 10 % of sensing distance |
| Response time / ·´‘ª•rég |
50 ms Max. |
2 ms Max. |
| Operating voltage / ¹¤×÷늉º |
AC90 ~ 260 V |
DC10 ~ 30 V |
| Current consumption / ÏûºÄëŠÁ÷ |
2 mA Max. |
¨Q 8 mA no-load |
| Load current / Ø“ÝdëŠÁ÷ |
5~100 mA Max. |
100 mA Max. at DC 30V |
| Leakage current / ©ëŠÁ÷ |
¨Q 2.0mA no-load |
¨Q 1.1 mA no-load |
| Residual voltage / šˆðN늉º |
¨Q AC 4V |
¨Q DC 1.5V |
| Insulation resistance / ¸ôëx×迹 |
20M ¦¸ min. (DC500V) |
| Voltage withstandability / ½^¾‰Ä͉º |
AC1000V 60Hz for 60 Sec. |
| Operating temperature / ¹¤×÷œØ¶È¹ ‡ú |
-20¡æ ~ + 60¡æ |
-20¡æ ~ + 60¡æ |
| Protection degree / ·ÀË®µÈ¼‰ |
IP 66 |
IP 66 |
| Wiring method / ³ö¾€·½Ê½ |
Pre-wire Ø4.2 x 2M/2-wires |
M8 pigtailed type /M8 ½Óî^15cm 늾€Ê½ |
Pre-wire Ø4.2 x 2M/3-wires |
| Weight / ÖØÁ¿ |
Approx. 56g |
Approx. 15g |
Approx. 60g |
Approx. 18g |
