| 屏幕尺寸 |
8.4"/10.1"/15"(依型号可选) |
| 亮度 |
300/350/380/400/450/800(typ.)(依型号可选) |
| 分辨率 |
640x480/800x600/1024x768(依型号可选) |
| 对比度 |
400:1/500:1/600:1/1200:1 (typ.)(依型号可选) |
| 触摸屏 |
4 Wire Resistive/5 Wire Resistive |
| 阳光下可读 |
Sunlight Readable Touch Screen |
| 系统规格 |
| CPU |
Intel Atom N270 1.6GHz |
| BIOS |
AMI System BIOS |
| 芯片组 |
Intel 945 GSE + ICH7M Chipset |
| 内存 |
1 x SODIMM, 最大支持2G DDR2 400/533 |
| 网络控制器 |
Dual Realtek RTL8111B GigaLAN |
| 存储 |
4G Compact Flash Card |
| 扩展槽 |
1 x Mini PCI, 1 x CF |
| I/O连接端口 |
背板I/O端口 |
2 x RJ-45(10/100/1000 Mpbs), 1 x PS/2, 1 x VGA(DB-15), 1 x DC-in Jack(Lockable), 2x USB 2.0, 1x for RS232/422/485*(Optional), WLAN antenna SMA in top(Optional)
| 前面板控制键 |
控制键 |
1x 电源开关 |
1x 向上键 |
1x 向下键 |
3x 复位键 |
LED 指示灯 |
电源 On/ Off, HDD读写 |
| 机械结构和环境特征 |
| 尺寸 (W x L x H) |
277 x 219.5 x 59.7 mm |
| 淨重(公斤) |
2 .3Kg/2.5 Kg/3 Kg (w/o accessories)(依型号可选) |
| 操作温度 |
`-25 deg.C to 60 deg.C |
| IP Proof |
IP65 |
| 操作湿度 |
10% to 90% (non condensing) |
| 安装方式 |
VESA mount, Vehicle mount |
| 认证 |
CE, FCC ClassB,ul |
Shock* Operating:30g for 18ms, 300m/s2 Vibration* Operating: 1.60/1.96/2.18 g rms for XYZ / 5-500Hz . |
| 电源输入 |
DC 12V w/ lockable connector |
