显示规格 |
尺寸 |
4.3" |
亮度 |
270(typ.) |
分辨率 |
480*800 |
对比度 |
800:1 (typ.) |
触摸屏 |
Projected Capacitive Multi Touch |
系统规格 |
处理器 |
TI Cortex A8 OMAP DM3730 1.0GHz |
内存 |
· 512MB MDDR
· 512MB NAND Flash |
存储 |
External Micro SD Card(Up to 32G ) |
音频 |
1.2W Speaker (internal) |
扩展卡插槽 |
1 x Micro SD card slot (internal) |
无线通信 |
无线网路 |
Support 802.11 2.4GHz b/g/n |
蓝牙 |
Bluetooth(2.1+EDR) |
WWAN |
3.5 G (Optional) |
GPS |
Built-in GPS module(SiRF based solution) |
I/O 接口 |
上方I/O 接口 |
1 x Headset jack |
下方I/O 接口 |
1 x Micro USB type B |
产品尺寸与环境规格 |
工作温度 |
-10 deg.C to 60 deg.C |
防水防尘等级 |
IP66 |
相对湿度 |
95% RH (non condensing) |
认证 |
CE, FCC, CCC, UL |
Gross Weight(kg)(single pcking) |
230g |
Shock |
MIL-STD-810G M516.6 |
Vibration |
MIL-STD-810G M514.6 |
Drop |
MIL-STD-810G M516.6, 5 ft, Free to concrete |
电器规格 |
电池规格 |
Li-Ion battery 2400 mAh (1S1P) |
电源配适器 |
5V/1A , USB Adapter |
Product Specification |
OS |
· Default Android 2.3.4
· Microsoft® Windows Mobile® 6.5 Professional (Optional)
· Microsoft® Windows CE 6.0 (Optional) |
