²úÆ·Ãû³Æ£º
µ¥ÏֱࣨÁ÷£©¹Ì̬µ÷ѹÆ÷
ÐÍ ºÅ£º
µ¥ÏֱࣨÁ÷£©¹Ì̬µ÷ѹÆ÷ Ê©Ä͵µçÆø¼¯ÍÅÓÐÏÞ¹«Ë¾£¨²úµØ£ºÏã¸Û£©
¹æ¸ñ·ÖÀà |
S-480V10A S-480V50A |
S-480D10A S-480D60A |
Specifiction |
S-480V25A S-480V60A |
S-480D25A S-480D80A |
classification |
S-480V40A S-480V80A |
S-480D40A S-480D90A |
S-480D50A S-480D100A |
ÍâÐͳߴç |
Outine Dimension(mm) |
57.0L*44.0W*27.0H |
57.0L*44.0W*27.0H |
¸ºÔصçѹ |
Load voltage |
380VAC 480VAC |
380VAC 480VAC |
¸ºÔصçÁ÷ |
Load Current |
10A 25A 40A 50A 60A 75A 80A 90A 100A |
¿ØÖƵçѹ |
Control Voltage |
VR:250K¦¸/110VAC 500K¦¸/220VAC |
3-32VDC |
¿ØÖƵçÁ÷ |
Control Current |
DC3-25mA |
̬ͨѹ½µ |
On Voltage |
¡Ü1.5V |
¡Ü1.5V |
¶Ï̬©µçÁ÷ |
Off leakage Current |
¡Ü2mA |
¡Ü2mA |
¶Ï̬ʱ¼ä |
On-off Time |
¡Ü10mS |
½éÖÊÄÍѹ |
Dielectric Strength |
2500VAC(ÓëÉ¢ÈȰ壩 |
2500VAC |
¾øÔµµç×è |
Lnsulation Resistance |
1000M¦¸/500VDC |
1000M¦¸/500VDC |
»·¾³ÎÂ¶È |
Ambient Temperature |
-30¡æ- +75¡æ |
-30¡æ- +75¡æ |
°²Ö÷½Ê½ |
Mounting methods |
ÂÝ˨¹Ì¶¨ Bolts fixed |
¹¤×÷ָʾ |
The work instructions |
LED |
ÖØÁ¿ |
Weight |
150g |
150g |
˵Ã÷ |
Explanation |
1.¸ºÔØ10A,±ØÐë°²×°É¢ÈÈÆ÷,40AÒÔÉϼӷçÉÈÇ¿Àä»òË®Àä |
2.ʹÓøÐÐÔ¸ºÔØʱ,ÇëÎñ±ØÔÚÊä³ö¶Ë²¢½ÓһѹÃôµç×è,ȡֵΪ¸ºÔصçѹµÄ1.6-1.9±¶ |
1.10A ovryload:lt must install radiator:above 40A:it need cold fans or watre-cooling.2.when use emotional overload,please connect a emotional resistance in the export end,the v alue is 1.6-1.9times than overload voltage. |
