²úÆ·Ãû³Æ£º
µ¥Ïà¹Ì̬¼ÌµçÆ÷£¨Ê©Ä͵£©
ÐÍ ºÅ£º
µ¥Ïà¹Ì̬¼ÌµçÆ÷£¨Ö±Á÷3-32VDC¿ØÖÆ£© Ê©Ä͵µçÆø¼¯ÍÅÓÐÏÞ¹«Ë¾£¨²úµØ£ºÏã¸Û£©
¹æ¸ñ·ÖÀà |
SSR-10DA SSR-50DA |
SSR-10DA-H SSR-50DA-H |
Specifiction |
SSR-15DA SSR-60DA |
SSR-15DA-H SSR-60DA-H |
classification |
SSR-25DA SSR-75DA |
SSR-25DA-H SSR-75DA-H |
SSR-40DA SSR-90DA |
SSR-40DA-H SSR-90DA-H |
ÍâÐͳߴç |
Outine Dimension(mm) |
62.0L*44.0W*23.0H |
62.0L*44.0W*23.0H |
¸ºÔصçѹ |
Load voltage |
24-380VAC(»ù±¾ÐÍ) £¨Basic model) |
90-480VAC(¸ßѹÐÍ£© £¨High pressure type) |
¸ºÔصçÁ÷ |
Load Current |
10A 15A 25A 40A 50A 60A 75A 80A 90A |
¿ØÖƵçѹ |
Control Voltage |
3-32VDC |
3-32VDC |
¿ØÖƵçÁ÷ |
Control Current |
DC3-25mA |
DC3-25mA |
̬ͨѹ½µ |
On Voltage |
¡Ü1.5V |
¡Ü1.5V |
¶Ï̬©µçÁ÷ |
Off leakage Current |
¡Ü2mA |
¡Ü2mA |
¶Ï̬ʱ¼ä |
On-off Time |
¡Ü10mS |
¡Ü10mS |
½éÖÊÄÍѹ |
Dielectric Strength |
2500VAC |
2500VAC |
¾øÔµµç×è |
Lnsulation Resistance |
1000M¦¸/500VDC |
1000M¦¸/500VDC |
»·¾³ÎÂ¶È |
Ambient Temperature |
-30¡æ- +75¡æ |
-30¡æ- +75¡æ |
°²Ö÷½Ê½ |
Mounting methods |
ÂÝ˨¹Ì¶¨ Bolts fixed |
¹¤×÷ָʾ |
The work instructions |
LED |
LED |
ÖØÁ¿ |
Weight |
132g |
132g |
˵Ã÷ |
Explanation |
1.¸ºÔØ10A,±ØÐë°²×°É¢ÈÈÆ÷,40AÒÔÉϼӷçÉÈÇ¿Àä»òË®Àä |
2.ʹÓøÐÐÔ¸ºÔØʱ,ÇëÎñ±ØÔÚÊä³ö¶Ë²¢½ÓһѹÃôµç×è,ȡֵΪ¸ºÔصçѹµÄ1.6-1.9±¶ |
1.10A ovryload:lt must install radiator:above 40A:it need cold fans or watre-cooling.2.when use emotional overload,please connect a emotional resistance in the export end,the v alue is 1.6-1.9times than overload voltage. |
