Output mothod Ý”³öģʽ |
NPN N.O. |
SC¡õ3010-N |
SC¡õ3010-NK |
SC¡õ3010-NK1 |
NPN N.C. |
SC¡õ3010-N2 |
SC¡õ3010-N2K |
SC¡õ3010-N2K1 |
PNP N.O. |
SC¡õ3010-P |
SC¡õ3010-PK |
SC¡õ3010-PK1 |
PNP N.C. |
SC¡õ3010-P2 |
SC¡õ3010-P2K |
SC¡õ3010-P2K1 |
NPN N.O./N.C. PNP N.O./N.C. |
SC3010-KP2 |
SC3010-KP2K |
¨C |
SCR N.O. |
SC3010-A |
SC3010-AK |
¨C |
SCR N.C. |
SC3010-A2 |
SC3010-A2K |
¨C |
Sensing surface / ™zœy·½Ïò |
Shielded / ¸ôëxÐÍ |
Description / ÍâÐÍ |
Standard / ˜ËœÊM30 |
Standard sensing object / ˜ËœÊ™zœyÎï |
Iron 30 x 30 x 1 mm |
Sensing distance / ™z³ö¾àëx |
10 mm |
Secure sensing distance / ½¨×h¾àëx |
0 to 8 mm |
Hysteresis / ßtœþ |
¨Q 10 % of sensing distance |
Response time / ·´‘ª•rég |
DC Type 3.3 ms Max. or AC Type 50ms |
Operating voltage / ¹¤×÷늉º |
DC 12 ~ 24V or AC90 ~ 260 V |
Current consumption / ÏûºÄëŠÁ÷ |
DC : ¨Q 8 mA no-load or AC : 2 mA Max |
Load current / Ø“ÝdëŠÁ÷ |
DC : 100 mA Max at DC 24V or AC : 5 ~ 300 mA Max |
Leakage current / ©ëŠÁ÷ |
¨Q 1.1 mA no-load |
Residual voltage / šˆðN늉º |
¨Q DC 1.5V |
Insulation resistance / ¸ôëx×迹 |
20M¦¸ min. (DC500V) |
Voltage withstandability / ½^¾‰Ä͉º |
AC1000V 60Hz for 60 Sec. |
Operating temperature / ¹¤×÷œØ¶È¹ ‡ú |
-20¡æ ~ + 60¡æ |
Protection degree / ·ÀË®µÈ¼‰ |
IP 66 |
Wiring method / ³ö¾€·½Ê½ |
N/P : Ø5.2x 2M / 3-wires KP2 :Ø5.2x2M / 4-wires AC :Ø5.2x2M / 2-wires |
M12 pigtailed type / M12 ½Óî^15cm늾€Ê½ |
M12 plug-in connector type / M12 ½Óî^ |
Weight / ÖØÁ¿ |
SC |
Approx. 145g |
Approx. 90g |
K1:Approx.80g M1:Approx. 100g |
SCL |
Approx. 165g |
Approx. 110g |
K1:Approx.100g M1:Approx. 120g |
