²úÆ·Ãû³Æ£º
PM12-02NB,PM12-04NB,PM12-04S½Ó½ü¿ª¹Ø
ÐÍ ºÅ£º
fotek½Ó½ü¿ª¹ØPM12-02NB,PM12-04NB,PM12-04S
̨ÍåÑôÃ÷Ô²ÖùÐͽӽü¿ª¹Ø²úÆ·Ñ¡ÐÍ Ô²Ðνӽü¿ª¹ØPM12-04NS£¬PM12-02N,PM12-04N,PM12-02P
ÐͺŠ|
Êä³ö״̬ |
Êä³ö·½Ê½ |
¹¤×÷µçѹ |
¸ÐÓ¦¾àÀë |
·´Ó¦ÆµÂÊ |
°²×°·½Ê½ |
PM08-01N |
NO |
NPN |
10~30VDC |
1.0mm |
2.5KHZ |
Flushed |
PM08-01NB |
NC |
NPN |
PM08-01P |
NO |
PNP |
PM08-01PB |
NC |
PNP |
PM12-02N |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB |
NC |
NPN |
PM12-02P |
NO |
PNP |
PM12-02PB |
NC |
PNP |
PM12-02N-S |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB-S |
NC |
NPN |
PM12-02P-S |
NO |
PNP |
PM12-02PB-S |
NC |
PNP |
PM12-04N-S |
NO |
NPN |
10~30VDC |
4.0mm |
2.5KHZ |
Non-Flushed |
PM12-04NB-S |
NC |
NPN |
PM12-04P-S |
NO |
PNP |
PM12-04PB-S |
NC |
PNP |
PM12-02N |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB |
NC |
NPN |
PM12-02P |
NO |
PNP |
PM12-02PB |
NC |
PNP |
PM12-04N |
NO |
NPN |
10~30VDC |
4.0mm |
2.5KHZ |
Non-Flushed |
PM12-04NB |
NC |
NPN |
PM12-04P |
NO |
PNP |
PM12-04PB |
NC |
PNP |
PM12-02S |
NO |
SCR |
90~250VAC |
2.0mm |
20HZ |
Flushed |
PM12-02SB |
NC |
SCR |
PM12-04S |
NO |
SCR |
90~250VAC |
4.0mm |
20HZ |
Non-Flushed |
PM12-04SB |
NC |
SCR |
PM18-05N |
NO |
NPN |
10~30VDC |
5.0mm |
2.5KHZ |
Flushed |
PM18-05NB |
NC |
NPN |
PM18-05P |
NO |
PNP |
PM18-05PB |
NC |
PNP |
PM30-10N-S |
NO |
NPN |
10~30VDC |
10.0mm |
500KHZ |
Flushed |
PM30-10NB-S |
NC |
NPN |
PM30-10P-S |
NO |
PNP |
PM30-10PB-S |
NC |
PNP |
PM30-15N-S |
NO |
NPN |
10~30VDC |
15.0mm |
500KHZ |
Non-Flushed |
PM30-15NB-S |
NC |
NPN |
PM30-15P-S |
NO |
PNP |
PM30-15PB-S |
NC |
PNP |
PM30-10S |
NO |
SCR |
90~250VAC |
10.0mm |
20HZ |
Flushed |
PM30-10SB |
NC |
SCR |
PM30-15S |
NO |
SCR |
90~250VAC |
15.0mm |
20HZ |
Non-Flushed |
PM30-15SB |
NC |
SCR |
, ce9d8; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0cm; WIDTH: 68pt; HEIGHT: 18pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: black 1pt solid; PADDING-TOP: 0cm" width=91>
NO |
SCR |
90~250VAC |
4.0mm |
20HZ |
Non-Flushed | | |
PM12-04SB |
NC |
SCR | | |
PM18-05N |
NO |
NPN |
10~30VDC |
5.0mm |
2.5KHZ |
Flushed | | |
PM18-05NB |
NC |
NPN | | |
PM18-05P |
NO |
PNP | | |
PM18-05PB |
NC |
PNP | | |
PM30-10N-S |
NO |
NPN |
10~30VDC |
10.0mm |
500KHZ |
Flushed | | |
PM30-10NB-S |
NC |
NPN | | |
PM30-10P-S |
NO |
PNP | | |
PM30-10PB-S |
NC, FONT> |
PNP | | |
PM30-15N-S |
NO |
NPN |
10~30VDC |
15.0mm |
500KHZ |
Non-Flushed | | |
PM30-15NB-S |
NC |
NPN | | |
PM30-15P-S |
NO |
PNP | | |
PM30-15PB-S |
NC |
PNP | | |
PM30-10S |
NO |
SCR |
90~250VAC |
10.0mm |
20HZ |
Flushed | | |
PM30-10SB |
NC |
SCR | | |
PM30-15S |
NO |
SCR |
90~250VAC |
15.0mm |
20HZ |
Non-Flushed | | |
PM30-15SB |
NC |
SCR | | |
