| General specifications |
| Sensing range |
80 ... 2000 mm |
| Adjustment range |
120 ... 2000 mm |
| Unusable area |
0 ... 80 mm |
| Standard target plate |
100 mm x 100 mm |
| Transducer frequency |
approx. 180 kHz |
| Response delay |
65 ms minimum
195 ms factory setting |
| Indicators/operating means |
| LED green |
solid: Power-on
flashing: Standby mode or program function object detected |
| LED yellow 1 |
solid: object in evaluation range
flashing: program function |
| LED yellow 2 |
solid: object in detection range
| LED red |
solid: temperature/program plug not connected
flashing: fault or program function object not detected |
| Temperature/TEACH-IN connector |
Temperature compensation , Evaluation range programming , output function setting |
