FUNCTION |
COM-9G45 |
Kernel |
CPU |
ATMEL AT91SAM9G45£¬ARM926EJ-S£¬400MHz |
System RAM |
64MB DDR2 |
Flash |
128MB (up to 256MB) |
Graphic Chip |
16-bit LCD controller by CPU |
Rtc |
YES |
Watchdog Timer |
YES |
Power Management |
NO |
Reset |
H/W reset & S/W reset (by register setting) |
I/O (All interfaces with industrial TTL 3.3V Level) |
UART |
TTL level x5 (4-wire x1 & 2-wire x4) |
Ethernet LAN |
10/100Mbps |
USB 2.0 Client |
1(High speed) |
USB Host |
1(High speed) |
SD/MMC |
1(4-wire) |
Touch |
1(4-wire resistive type) |
System bus |
no |
IIC interface |
1 |
SPI interface |
1 |
GPIO |
12-pin 3.3V TTL level GPIOs |
IIS |
1 |
Multimedia |
Graphic Chip |
CPU internal 24-bit LCD controller |
Resolution |
Max 1280¡Á860¡¢24bits (320 x 240 ~ 1280 x 860 as optional) |
LCD interface |
16-bit TTL |
Audio |
Headphone out and Mic in |
Power |
Power input |
3.3 VDC (+-5%) & 3.0 VDC (+-5%) |
Power Consumption |
TBD |
Mechanical & Environment |
Size |
45MM*45MM*3.2MM |
Operating Temperature |
-20 ~ 70¡ã C (-40 ~85¡ã C by project base) |
Operating Humidity |
5 ~ 95 % relative humidity, non-condensing |
Other |
RoHS |
YES |
Certifications |
CE/FCC Class A |
Software Support |
Embedded Linux 2.6 (WCE6.0 by project support) |
