²úÆ·ÓÅÊÆ
Ó¯Åô·É¹«Ë¾Ê׿îAT91SAM9G45¹¤¿ØÖ÷°å£¬¾«Éè¼Æ£¬µÍ³É±¾£¬¿ÉÐÅÀµ
¡ô 400M¸ßËÙARM926EJºËÐÄ£»
¡ô µ¥¿Å64M×Ö½ÚDDR2 SDRAM£¬³É±¾¸üµÍÁ®£»
¡ô ´óÈÝÁ¿°åÔØµç×ÓÅÌ£¬¸ü¶àÓû§¿Õ¼ä£»
¡ô ±ê×¼PC104¶¨Î»Éè¼Æ,³ß´ç96x90mm,ÅúÁ¿Ê¹Óóɱ¾¸üµÍ£»
¡ô 10M/100MÒÔÌ«Íø£»
¡ô ºËÐİå¶ÀÁ¢RTC,×ßʱ¾«×¼£»
¡ô ARM9ÖÐ×îÓÅÐãµÄÏÔʾÐÔÄÜ£¬ ͬʱ֧³ÖLCDºÍLVDS£¬·Ö±æÂʸߴï1280*860£»
¡ô 6·RS232´®¿Ú£¨ÆäÖÐ1·¿É×÷ΪTTLÊä³ö£©£»
¡ô °åÔØIIS ÒôƵ£¬ÒôÖʸüÌðÃÀ£»
¡ô ÍⲿÀ©Õ¹1*IIC,1*SPI½Ó¿Ú £¬·½±ãÍâ½ÓÉ豸£»
¡ô Ö§³ÖSD¿¨½Ó¿Ú£¬´óÈÝÁ¿´æ´¢£»
¡ô 1·¸ßËÙUSB 2.0 Device½Ó¿Ú£»
¡ô 2·¸ßËÙUSB 2.0 Host½Ó¿Ú£»
¡ô רҵWINCE 6.0¡¢LINUX 2.6²Ù×÷ϵͳ֧³Ö£¬Ö§³ÖSD¿¨³õʼ»¯£¬¿É ÓÃÒÔÌ«Íø£¬USBÉý¼¶²Ù×÷ϵͳ£»
¡ô ºËÐİ嵥¶ÀÉè¼Æ£¬¸ß¼¯³É¶È£¬¿ÉÒÔÖ±½ÓÓ¦Ó㬿ɸù¾Ý¿Í»§¶¨ÖÆÖ÷°å£»
¡ô ¶àÄêATMELÉè¼Æ¾Ñ飬¶Àµ½µÄ²úÆ·Òâʶ£»
¡ô ÍÆ¼öÓ¦ÓãºÒ½ÁÆ¡¢ÒÇ±í¡¢ÏÔʾÖÕ¶Ë£»
¹¦ÄÜ
FUNCTION |
EAC-0945 |
Kernel |
CPU |
ATMEL AT91SAM9G45£¬ARM926EJ-S£¬400MHz |
System RAM |
64MB DDR2 |
Flash |
128MB (up to 256MB) |
Graphic Chip |
16-bit LCD controller by CPU |
Rtc |
YES |
Watchdog Timer |
YES |
Power Management |
NO |
Exernal Reset |
H/W reset & S/W reset (by ADM706R) |
I/O |
UART |
TTL level x6 (4-wire x1 & 2-wire x4) |
Ethernet LAN |
10/100Mbps |
USB 2.0 Client |
1(High speed) |
USB Host |
2(High speed) |
SD/MMC |
1(4-wire) |
Touch |
1(4-wire resistive type) |
System bus |
no |
IIC interface |
1 |
SPI interface |
1 |
GPIO |
12-pin 3.3V TTL level GPIOs |
IIS |
1 |
KEYPAD |
8x8 matrix keypad expand via IIC interface(optional) |
Multimedia |
Graphic Chip |
CPU internal 24-bit LCD controller |
Resolution |
Max 1280¡Á860¡¢24bits (320 x 240 ~ 1280 x 860 as optional) |
LCD interface |
16-bit TTL/16-bit LVDS connector |
Audio |
Headphone out and Mic in |
Power |
Power input |
5.0 VDC (+-5%) & 12.0 VDC (+-5%, for backlight) |
Power Consumption |
TBD |
Mechanical & Environment |
Board Size |
96x90MM |
Weight |
TBD |
Operating Temperature |
-20 ~ 70¡ã C (-40 ~85¡ã C by project base) |
Operating Humidity |
5 ~ 95 % relative humidity, non-condensing |
Other |
RoHS |
YES |
Certifications |
CE/FCC Class A |
Software Support |
Embedded Linux 2.6 (WCE6.0 by project support) |
ϵͳ¿òͼ
¶©¹ºÐÅÏ¢
Part No. |
CPU |
RAM |
Flash Memory |
RS232 |
LAN |
USB Host |
USB OTG |
LCD/LVDS |
video decoder |
Touch |
SD |
IIC |
SPI |
size |
Power Input |
Operating temp. |
EAC-0945 |
At91sam
9g45b |
64m |
128m |
6xRS232 |
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-20-70 |
EAC-0945-B1 |
At91sam
9g45b |
64m |
256m |
6xRS232 |
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-20-70 |
EAC-0945-B2 |
At91sam
9g45b |
64m |
128m |
4xRS232
2xTTL |
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-20-70 |
EAC-0945-B3 |
At91sam
9g45b |
64m |
256m |
4xRS232
2xTTL |
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-20-70 |
EAC-0945-B4 |
At91sam
9g45b |
64m |
128m |
4xRS232
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-20-70 |
EAC-0945-B5 |
At91sam
9g45b |
64m |
128m |
6 |
1 |
2 |
1 |
16-bit |
yes |
1 |
1 |
1 |
96x90mm |
5.0v |
-40-85 |
³ß´çÌØÕ÷
