| Model / 型號 |
NPN D.on |
OAP-2008-NK |
OAP-2008S-NK |
OAP-2016-NK |
OAP-2016S-NK |
| PNP D.on |
OAP-2008-PK |
OAP-2008S-PK |
OAP-2016-PK |
OAP-2016S-PK |
| Sensing type / 檢出方式 |
Through beam / 對照式 |
| Resolution / 分辨率 |
30 mm opaque object 不透明物體 |
| Sensing distance / 檢出距離 |
0.6 M ~ 5 M |
0.3 M ~ 2 M |
0.9 M ~ 5 M |
0.5 M ~ 2 M |
| Sensing Height / 檢測高度 |
140 mm |
300 mm |
| Emitting light / 發光源 |
Infrared LED(紅外線發光LED):850 nm |
| No.of Beams/光軸數 |
8 |
16 |
Beam pitch / 光軸間距 |
20 mm |
| Indicating LED / LED指示燈 |
5 LEDs each on emitter and receiver. |
7LEDs each on emitter and receiver. |
| LEDs blink from top to bottom under the normal emission. All LEDs light up under the emitting circuit failure and will become blinking until the normal emission. |
| Running type / 運轉方式 |
More than a beam is covered ON﹙Dark On﹚ 任意一個光束被遮斷即輸出 |
| Operating voltage / 工作電壓 |
DC12 ~ 24 V±10% (ripple P-P:10% Max.) |
| Current Consumption / 消耗電流 |
Transmitter:90 mA Max. |
Transmitter:135 mA Max. |
| Receiver:35 mA Max. |
Receiver:70 mA Max. |
| Load current / 負載電流 |
100 mA Max at DC 24V |
| Protection circuit / 保護電路 |
Reversed Supply circuit protection, Short circuit protection output 電源反接保護及輸出短路保護 |
| Response time / 反應時間 |
Off to On:15 ms Max. |
| On to Off:20 ms Max. |
| Insulation resistance / 隔離阻抗 |
20MΩ min. (DC500V) |
| Voltage withstandabiligy / 絕緣耐壓 |
AC1000V 60Hz for 60 Sec. |
| Operating temperature/工作溫度 |
- 10 ℃ ~ + 45℃ ﹙No freezing allowed不可結霜,結冰﹚ |
| Ambient humidity / 工作溼度 |
35% ~ 85% RH 相對溼度 |
| Storage temperature / 儲存時溫度 |
| Storage humidity / 儲存時溼度 |
35% ~ 95% RH 相對溼度 |
| Protection degree / 防水等級 |
IP62 |
| Material / 外觀材質 |
ABS |
| Wiring method / 出線方式 |
Transmitter:M12 pigtailed type(5P) / M12接頭15cm電線式 |
| Receiver:M12 pigtailed type(5P) / M12接頭15cm電線式 |
Weight /重量 |
Approx.200g |
Approx.253g |
