| ÖÖ Àà |
¸ºÑ¹ |
Õýѹ |
| £101kPaÐÍ |
100kPaÐÍ |
1MPaÐÍ |
| ±ê×¼ÐÍ |
ÇáÁ¿ÐÍ |
±âƽÐÍ |
IP67ÐÍ |
±ê×¼ÐÍ |
±ê×¼ÐÍ |
| ÐͺŠ|
ÑÇÖÞÐÍ |
DP2-20 |
DP2-80 |
DP2-60 |
DP2-21 |
DP2-22 |
| ±±ÃÀÐÍ(×¢) |
DP2-40N |
| Å·ÖÞÐÍ |
DP2-40E |
| ѹÁ¦ÖÖÀà |
±ê׼ѹÁ¦ |
| ¶î¶¨Ñ¹Á¦·¶Î§ |
0¡«£101.3kPa |
0¡«100.0kPa |
0¡«1.000MPa |
| É趨ѹÁ¦·¶Î§ |
5.1¡«£101.3kPa
0.052¡«£1.033kgf/cm2, 0.051¡«£1.013bar
0.74¡«£14.70psi, 38¡«£760mmHg
1.5¡«£29.9inHg |
£5.0¡«100.0kPa
£0.051¡«1.020kgf/cm2
£0.050¡«1.000bar
£0.72¡«14.50psi |
£0.050¡«1.000MPa
£0.51¡«10.20kgf/cm2
£0.50¡«10.00bar
£7.2¡«145.0psi |
| ÄÍѹÁ¦ |
490kPa |
1.47MPa |
| ÊÊÓÃÁ÷Ìå |
·Ç¸¯Ê´ÐÔÆøÌå |
| ¿ÉÑ¡µ¥Î» |
kPa£¬kgf/cm2£¬bar£¬psi£¬mmHg£¬inHg |
kPa£¬kgf/cm2£¬
bar£¬psi |
MPa£¬kgf/cm2£¬
bar£¬psi |
| µçÔ´µçѹ |
12¡«24V DC %¡¡Âö¶¯P-P10%ÒÔÏ |
| ÏûºÄµçÁ÷ |
50mAÒÔÏÂ |
±È½ÏÊä³ö
(±È½ÏÊä³ö1)
(±È½ÏÊä³ö2) |
<ÑÇÖÞ¡¢±±ÃÀÐÍ(±ê×¼NPNÊä³öÐÍ£¬±âƽÐͺÍIP67ÐÍ)>
NPN¿ªÂ·¼¯µç¼«¾§Ìå¹Ü
·×î´óÁ÷ÈëµçÁ÷£º100mA
·Íâ¼Óµçѹ£º30V DCÒÔÏÂ(±È½ÏÊä³öºÍ0VÖ®¼ä)
·Ê£Óàµçѹ£º1VÒÔÄÚ(Á÷ÈëµçÁ÷Ϊ100mAʱ)
0.4VÒÔÏÂ(Á÷ÈëµçÁ÷Ϊ16mAʱ) |
<±±ÃÀÐÍ(±ê×¼PNPÊä³öÐÍ)£¬Å·ÖÞÐÍ>
PNP¿ªÂ·¼¯µç¼«¾§Ìå¹Ü
·×î´óÔ´µçÁ÷£º100mA
·Íâ¼Óµçѹ£º30V DCÒÔÏÂ(±È½ÏÊä³öºÍ£«VÖ®¼ä)
·Ê£Óàµçѹ£º2VÒÔÏÂ(Ô´µçÁ÷Ϊ100mAʱ) |
| Êä³öģʽ |
¹²ÓÐ4ÖÖģʽ£ºÓ¦²îģʽ¡¢´°Ê½±È½Ïģʽ¡¢Ë«Êä³öģʽ¡¢×Ô¶¯ÁéÃô¶ÈÉ趨ģʽ
(¿Éͨ¹ý°´Å¥²Ù×÷Ñ¡Ôñ) |
| Ó¦²î |
1digit(µ«ÊÇ£¬Ê¹ÓÃÓ¦²îģʽʱ¿É¸Ä±ä) |
| ÖØ¸´¾«¶È |
±0.2%F.S.±1digitÒÔÄÚ |
| ·´Ó¦Ê±¼ä |
2.5msÒÔÏÂ |
| ¶Ì·±£»¤ |
| Ä£ÄâµçѹÊä³ö |
Êä³öµçѹ£º1¡«5V(ÔڶѹÁ¦·¶Î§ÄÚ)
Áãµã£º1V±5%F.S.ÒÔÄÚ
·ù¶È£º4V±5%F.S.ÒÔÄÚ
ÏßÐÔ£º±1%F.S.ÒÔÄÚ
Êä³ö×迹£ºÔ¼1kΩ |
| ÏÔʾ |
3 1/2λºìÉ«LEDÏÔʾ(³éÑùÂÊ£ºÔ¼4´Î/Ãë) |
| ¿ÉÏÔʾѹÁ¦·¶Î§ |
5.1¡«£101.3kPa
0.74¡«£14.70 psi, 38¡«£760mmHg
1.5¡«£29.9inHg |
£5.0¡«100.0kPa
£0.050¡«1.000bar
£0.72¡«14.50psi |
£0.050¡«1.000MPa
£0.51¡«10.20kgf/cm2
£0.50¡«10.00bar
£7.2¡«145.0psi |
| Ä£Äâ¶ÈÊýÅÌÏÔʾ |
LED¶ÈÊýÅÌÏÔʾÒÔÔ¼10%F.S.·ù¶È |
¹¤×÷״ָ̬ʾµÆ
(±È½ÏÊä³ö1) |
³ÈÉ«LED(±È½ÏÊä³ö1ONʱÁÁÆð) |
¹¤×÷״ָ̬ʾµÆ
(±È½ÏÊä³ö2) |
ÂÌÉ«LED(±È½ÏÊä³ö2ONʱÁÁÆð) |
¾³
ÐÔ
ÄÜ |
±£»¤¹¹Ôì |
±ê×¼±âƽºÍÇáÁ¿ÐÍ£ºIP40(IEC)£¬IP67ÐÍ£ºIP67(IEC) |
| ÖÜΧÎÂ¶È |
£10¡«£«50°C(×¢Òâ²»¿É½á¶¡¢½á±ù)£¬´æ´¢£º£10¡«£«60°C |
| ÖÜΧʪ¶È |
35¡«85%RH£¬´æ´¢£º35¡«85%RH |
| Ä͵çѹ |
AC1,000V 1·ÖÖÓ£¬ËùÓеçÔ´Á¬½Ó¶Ë×ÓÓëÍâ |
| ¾øÔµµç×è |
ËùÓеçÔ´Á¬½Ó¶Ë×ÓÓëÍâ¿ÇÖ®¼ä£¬50MΩÒÔÉÏ£¬»ùÓÚDC500VµÄ¸ß×è±í |
| ÄÍÕñ¶¯ |
ƵÂÊ£º10¡«150Hz£¬Ë«Õñ·ù£º0.75mm£¬X,YºÍZ¸÷·½Ïò2Сʱ |
| Äͳå»÷ |
¼ÓËÙ¶È£º100m/s2(Ô¼10G)£¬X£¬YºÍZ¸÷·½Ïò3´Î |
| ζÈÌØÐÔ |
³¬¹ýÖÜΧζȷ¶Î§£10¡«£«50°C£¬£«20°Cʱ¼ì²âѹÁ¦µÄ±1%F.S.ÒÔÄÚ |
| ѹÁ¦¿× |
ÑÇÖÞÐÍ |
±ê×¼£¬±âƽºÍIP67ÐÍ£ºRc(PT)1/8ÄÚÂÝÎÆ£¬ÇáÁ¿ÐÍ£ºM5ÄÚÂÝÎÆ |
| ±±ÃÀÐÍ |
±ê×¼ÐÍ£ºNPTF1/8ÄÚÂÝÎÆ£¬±âƽºÍIP67ÐÍ£ºNPT1/8ÄÚÂÝÎÆ |
| Å·ÖÞÐÍ |
±âƽºÍIP67ÐÍ£ºG(PF)1/8ÄÚÂÝÎÆ |
| ²ÄÖÊ |
ǰ¸Ç£ºABS£¬ºó¸Ç£ºPPS(²£Á§ÏËά¼Ó¹Ì)£¬ÏÔʾ±íÃæ£º±ûÏ©
ѹÁ¦¿×¸½¼þ£ºÑ¹ÖýпºÏ½ð[ÇáÐÍ£ºPOM(²£Á§ÏËά¼Ó¹Ì)£¬Ñ¹Á¦¿×ÊÇ»ÆÍ(¶ÆÄø)]
ǰÕÖ(½öIP67ÐÍ)£º¾Û̼Ëáõ¥ |
| µçÀ |
0.15mm2 5о·ÀÓÍÏðÆ¤µçÀ£¬³¤2m(IP67ÐÍ£º³¤5m) |
| µçÀÂÑÓ³¤ |
0.3mm2 ÒÔÉϵĵçÀÂÈ«³¤¿ÉÑÓ³¤ÖÁ100m(·ûºÏCE±ê¼ÇʱΪ10mÒÔÏÂ) |
| ÖØÁ¿ |
±ê×¼ÐÍ£ºÔ¼95g£¬±âƽÐÍ£ºÔ¼120g£¬IP67ÐÍ£ºÔ¼370g£¬ÇáÁ¿ÐÍ£ºÔ¼70g |
| ¸½¼þ |
DPX-02(ÓÃÓÚѹÁ¦¿×µÄÁù±ßÐβåÍ·)£º1¸ö(±ê×¼ÐÍ)£¬Ñ¹Á¦µ¥Î»±êÇ©£º1¸ö |
