This product is the interface board of PCI bus conformity which inputs a digital signal. The digital signal of 12 to 24VDC can be inputted. The input of a maximum of 32 points can be performed on one board. The driver (API-PAC(W32)) for Windows and Linux appending
Features
- It can respond to a common independently different external power supply because of the common composition of a 16-point unit.
- Since the PCI bus (personal computer) and the input-and-output interface are isolated by the photo-coupler, it excels in noise-protection nature.
- All the input signals can be used as an interruption input. Moreover, the edge of the input signal which generates interruption can also be chosen.
- It has the digital filter function for preventing the incorrect input by the noise or the chattering.
- PI-32L(PCI)H and PI-32L(PCI) are connector pin compatibles.
Specification
Digital I/O
Bus PCI
Function Input
Input 32
Output
Bidirection
Response speed 200µsec(max.)
Operation voltage Input: 12--24VDC
Built-in power supply
Input circuit Opto-isolated input (Sink output)
Output circuit
