Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¾«ÃÜcnc¸ß¹â»ú
²úÆ·Ãû³Æ£º ¾«ÃÜcnc¸ß¹â»ú
ÐÍ ºÅ£º DA-400T
¾«ÃÜcnc¸ß¹â»úDA-400T»úÆ÷˵Ã÷
ÏîÄ¿/»úÐÍ ITEM/MODEL£ºµÏ°Â400T
¼Ó¹¤²ÄÁÏ WORK MATERIAL£ºÑÇ¿ËÁ¦/PC/PET,ÊÖ»ú²£Á§
¹¤×÷̨ WORK TABLE
¹¤×÷̨ÐÎʽ Table£ºTÐͲÛ+Õæ¿Õƽ̨,TÐͲÛ+Ò±¾ß
¹¤×÷̨³ß´ç Table size: 400×400mm,400×400mm
×î´ó¹¤×÷¸ºÖØ Table load capacity: 100kg
¹¤×÷ÐÐ³Ì MOVEMENT & RANGE
µ¥Í·¼Ó¹¤ Single head processing: 400×400mm×120mm
Ö÷Öá±Ç¶ËÖÁ¹¤×÷Ì¨Ãæ Spindle nose to work table: 130mm
»ú´²¾«¶È ACCURACY
ÖáÔ˶¯¶¨Î»¾«¶È Positioning accuracy: 0.008/300mm
ÖáÖØ¸´¶¨Î»¾«¶È Repeatability accuracy: 0.005mm
Ö÷Öá SPINDLE
Ö÷ÖṦÂÊ Spindle power:    1.2/ 1.5 Kw(¿ÉÑ¡£©
Ö÷ÖáתËÙ Spindle speed range: 24000/40000/60000 rpm(¿ÉÑ¡£©
»»µ¶ÐÎʽ Change cutters form: Æø¶¯·½Ê½ £¨¿ÉÑ¡£ºÊÖ¶¯·½Ê½£©
¼Ð¾ß¹æ¸ñ Collet: Φ6 ¡¢6-4¡¢6-3.175±ä¾¶Ì×
½ø¸øËÙ¶È FEEDING SPEED
×î´ó¿ìËÙ½ø¸øËÙ¶È Rapid traverse: 15m/min
×î´óÇÐÏ÷½ø¸øËÙ¶È Cutting feed rate:  9m/min
ËùÐ趯Á¦»ú´²³ß´ç POWER / SIZE
ÆøÑ¹ Air pressure: 0.7¡«0.8mp
Õæ¿ÕÎüÁ¦ Pull of vacuum£º-(0.06-0.08)mp
µçÔ´ÒªÇó Power spec.: 220v/380v(¿ÉÑ¡£©½ÓµØ
»ų́ÍâÕÖ Shape sheet metal£º±êÅä°ëÕÖʽ£¨¿ÉѡȫÕÖʽ£©
×ܹ¦ÂÊ Total Power£º3Kw
ÖØÁ¿ Machine weight£º1600kg
»ų́ÍâÐγߴç Machine size£º1200*1400*1600mm
¾«ÃÜcnc¸ß¹â»úDA-400TÊýÂë¿ØÖÆÏµÍ³
¿ØÖÆÏµÍ³: ±¦Ôª/άºê/ïÆÖÂ
ͬʱ¼õËÙÖá: 4Öá
×îÉÙÒÆ¶¯µ¥Î»: 0.001mm
ÏÔʾÆ÷: ϵͳרÓÃÅäÌ×ÏÔʾÆÁ
ÓïÑÔ: ÖÐÎÄ/Ó¢ÎÄ
ϵͳÅÌ: 1G
Êý¾ÝÅÌ: 2G
ϵͳÅ̱£»¤: ¶ÁÈ¡£¬×Ô¶¯É±¶¾/¿ª»ú¸´Î»
Ö§³ÖÎļþ¸ñʽ: DXF/PLT/ENG/GCODE/DEMO/U00
ÊÖÒ¡Âö³å·¢ÉúÆ÷: MPG
¾«ÃÜcnc¸ß¹â»úDA-400TÆäËü±ê×¼Åä¼þ
Z Öá×Ô¶¯¶Ôµ¶ÒÇ: METROL
MPG: ±¦Ôª/άºê/ïÆÖÂ
ÅçË®×°ÖÃ:  360°È«·½Ïò ÅçË®×°Öà
ÊýÏÔÐÍ×¢ÓÍ»ú: ̨Í屦ÌÚ
¹¤×÷µÆ: LEDµÆ£¬ÈýÉ«µÆ£¬·À±¬µÆ
ÖÆ¾ß: ÑÇ¿ËÁ¦/ÂÁ¼Ó¹¤Öƾߠ
±¾¹«Ë¾¶Ô²úÆ·¹æ¸ñ£¬Éè¼ÆÌØÐÔ¾ù²»¶ÏÑо¿¸Ä½ø£¬ÉÏÊö²ÎÊýÈôÓиü¸ÄË¡²»ÁíÐÐ֪ͨ£¡
¹«Ë¾Ãû³Æ£º ¶«Ý¸ÊеϰÂÊý¿ØÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0769 82766709 / Ò¶ÏÍËÉ
ÊÖ»ú£º 13823137775
µØ Ö·£º ´óÁëɽÕòÁ¬Âí·Á¬Æ½Û×¹¤ÒµÔ°¶þÂ¥
ÓÊ ±à£º 523809
Ö÷ Ò³£º http://www.di-aocnc.com/
  • ÊÖ»ú²£Á§¾«µñ»ú
  • ÑÇ¿ËÁ¦¾«µñ»ú
  • CCD¶¨Î»µ¥Í·¾«µñ»ú
  • ÊÖ»úËܽºÍâ¿Ç¾«µñ»ú
  • ¾«ÃÜcnc¸ß¹â»ú
