ÊÖ»úËܽºÍâ¿Ç¾«µñ»úDA-600T»úÆ÷˵Ã÷
ÏîÄ¿/»úÐÍ ITEM/MODEL£ºDA-600T(˫ͷ»ú£©
¼Ó¹¤²ÄÁÏ WORK MATERIAL£ºÑÇ¿ËÁ¦/PC/PET,ÊÖ»ú²£Á§,ÊÖ»úËܽºÍâ¿Ç
¹¤×÷̨ WORK TABLE
¹¤×÷̨ÐÎʽ Table£ºTÐͲÛ+Õæ¿Õƽ̨,TÐͲÛ+Ò±¾ß
¹¤×÷̨³ß´ç Table size: 600×400mm,700×500mm
×î´ó¹¤×÷¸ºÖØ Table load capacity: 100kg
¹¤×÷ÐÐ³Ì MOVEMENT & RANGE
µ¥Í·¼Ó¹¤ Single head processing: 350×500×120mm
˫ͷͬʱ¼Ó¹¤ Two-headed simultaneously: £¨250/330£©×500×120mm
Ë«Ö÷ÖáÖÐÐľà Two-headed center distance: 250/330mm(¿Éµ÷£©
Ö÷Öá±Ç¶ËÖÁ¹¤×÷Ì¨Ãæ Spindle nose to work table: 130mm
»ú´²¾«¶È ACCURACY
ÖáÔ˶¯¶¨Î»¾«¶È Positioning accuracy: 0.008/300mm
ÖáÖØ¸´¶¨Î»¾«¶È Repeatability accuracy: 0.005mm
Ö÷Öá SPINDLE
Ö÷ÖṦÂÊ Spindle power: 1.2/ 1.5 /2.2 Kw(¿ÉÑ¡£©
Ö÷ÖáתËÙ Spindle speed range: 24000/40000/60000 rpm(¿ÉÑ¡£©
»»µ¶ÐÎʽ Change cutters form: Æø¶¯·½Ê½ £¨¿ÉÑ¡£ºÊÖ¶¯·½Ê½£©
¼Ð¾ß¹æ¸ñ Collet: Φ10/Φ6/Φ4/Φ3.175
½ø¸øËÙ¶È FEEDING SPEED
×î´ó¿ìËÙ½ø¸øËÙ¶È Rapid traverse: 15m/min
×î´óÇÐÏ÷½ø¸øËÙ¶È Cutting feed rate: 9m/min
ËùÐ趯Á¦»ú´²³ß´ç POWER / SIZE
ÆøÑ¹ Air pressure: 0.7¡«0.8mp,0.5¡«0.6mp
Õæ¿ÕÎüÁ¦ Pull of vacuum£º-(0.06-0.08)mp
µçÔ´ÒªÇó Power spec.: AC 220V (3P 4L)50~60Hz
»ų́ÍâÕÖ Shape sheet metal£º±êÅä°ëÕÖʽ£¨¿ÉÑ¡£ºÈ«ÕÖʽ£©
×ܹ¦ÂÊ Total Power£º5.5Kw
ÖØÁ¿ Machine weight£º1800kg
»ų́ÍâÐγߴç Machine size£º1470*1200*1600mm
ÊÖ»úËܽºÍâ¿Ç¾«µñ»úDA-600TÊýÂë¿ØÖÆÏµÍ³
¿ØÖÆÏµÍ³: ±¦Ôª/άºê/ïÆÖÂ
ͬʱ¼õËÙÖá: 4Öᣨµ¶¾ß°ë¾¶²¹³¥¹¦ÄÜ£©
×îÉÙÒÆ¶¯µ¥Î»: 0.001mm
ÏÔʾÆ÷: Display 10.4" COLOR TFT
ÓïÑÔ: ÖÐÎÄ/Ó¢ÎÄ
ϵͳÅÌ: 1G
Êý¾ÝÅÌ: 2G
ϵͳÅ̱£»¤: ¶ÁÈ¡£¬×Ô¶¯É±¶¾
Ö§³ÖÎļþ¸ñʽ: DXF/PLT/ENG/GCODE/DEMO/U00
ÊÖÒ¡Âö³å·¢ÉúÆ÷: MPG
ÊÖ»úËܽºÍâ¿Ç¾«µñ»úDA-600TÆäËü±ê×¼Åä¼þ
Z Öá×Ô¶¯¶Ôµ¶ÒÇ: METROL
MPG: ±¦Ôª/άºê/ïÆÖÂ
ÅçË®×°ÖÃ: 360°È«·½Ïò ÅçË®×°ÖÃ
ÊýÏÔÐÍ×¢ÓÍ»ú: ̨Í屦ÌÚ
¹¤×÷µÆ: LEDµÆ£¬ÈýÉ«µÆ£¬·À±¬µÆ
ÖÆ¾ß: GLASS/ACRYLIC ¼Ó¹¤ÓÃÖÆ¾ß
±¾¹«Ë¾¶Ô²úÆ·ÊÖ»úËܽºÍâ¿Ç¾«µñ»úDA-600TµÄ¹æ¸ñ£¬Éè¼ÆÌØÐÔ¾ù²»¶ÏÑо¿¸Ä½ø£¬ÉÏÊö²ÎÊýÈôÓиü¸ÄË¡²»ÁíÐÐ֪ͨ£¡
