̨ÍåÑôÃ÷fotek¼ÌµçÆ÷ HPR-100DA
¸ºÔصçÁ÷£º2A ¸ºÔصçѹ·¶Î§£º48-280VAC¡£ HFS40A ¸ºÔصçÁ÷£º2A¡¢3A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡£ HFS5427 ¸ºÔصçÁ÷£º2A¡¢3A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡£ HFS32 ¸ºÔصçÁ÷£º1A¡¢2A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡£ HFS41 ¸ºÔصçÁ÷£º3A¡¢4A¡¢5A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡¢48-530VAC¡£ HFS15 ¸ºÔصçÁ÷£º10A¡¢15A¡¢20A¡¢25A¡¢40A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡£ HFS34 ¸ºÔصçÁ÷£º10A¡¢15A¡¢20A¡¢25A¡¢40A¡¢50A¡¢60A¡¢70A¡¢80A¡¢100A ¸ºÔصçѹ·¶Î§£º48-280V£»48-440VAC¡¢48-530VAC¡¢48-660VAC¡£
Èý¡¢Ö±Á÷¹Ì̬¼ÌµçÆ÷£¨µ¥Ïò¹Ì̬¼ÌµçÆ÷£©£º HFS40 ¸ºÔصçÁ÷£º2A ¸ºÔصçѹ·¶Î§£º3-52.8VDC; 3-125VDC¡£ HFS27 ¸ºÔصçÁ÷£º2A ¸ºÔصçѹ·¶Î§£º3-60VDC; 3-100VDC¡£ HFS32 ¸ºÔصçÁ÷£º3A¡¢4A¡¢5A ¸ºÔصçѹ·¶Î§£º0-28.80VDC; 0-57.6VDC¡£ HFS33 ¸ºÔصçÁ÷£º7A¡¢10A¡¢12A¡¢20A¡¢40A¡¢50A¡¢80A¡¢100A ¸ºÔصçѹ·¶Î§£º30VDC¡¢50VDC¡¢100VDC¡¢150VDC¡¢200VDC¡¢400VDC¡¢500VDC¡£
ËÄ¡¢Ë«Â·³ö¹Ì̬¼ÌµçÆ÷ HFS28 ¸ºÔصçÁ÷£º25A¡¢40A¡¢50A ¸ºÔصçѹ·¶Î§£º£º48-280V£»48-440VAC¡£
Îå¡¢ÈýÏà¹Ì̬¼ÌµçÆ÷£º HFS24£º¸ºÔصçÁ÷£º10A¡¢15A¡¢20A¡¢25A¡¢40A¡¢60A ¸ºÔصçѹ·¶Î§£º48-440VAC¡¢48-530VAC¡£
Áù¡¢µç»úÕý·´×ª¹Ì̬¼ÌµçÆ÷£º HFS21£º¸ºÔصçÁ÷£º10A¡¢15A¡¢20A¡¢25A¡¢40A¸ºÔصçѹ·¶Î§£º48-440VAC¡£
¡¡µ¥ÏཻÁ÷´¥·¢¡¡SSR-10AA¡¡80¡«250VAC¡¡24¡«380VAC¡¡10A¡¡¡¡¡¡SSR-25AA¡¡25A¡¡¡¡¡¡SSR-40AA¡¡40A¡¡¡¡¡¡SSR-50AA¡¡50A¡¡¡¡¡¡SSR-75AA¡¡75A¡¡¡¡¡¡SSR-10AA-H¡¡80¡«250VAC¡¡90¡«480VAC¡¡10A¡¡¡¡¡¡SSR-25AA-H¡¡25A¡¡¡¡¡¡SSR-40AA-H¡¡40A¡¡¡¡¡¡SSR-50AA-H¡¡50A¡¡¡¡¡¡SSR-75AA-H¡¡75A¡¡
¡¡¡¡µçѹ¿Éµ÷ÐÍ¡¡SSR-10VA¡¡110V£¯250K£¬220V£¯500K£¬380V£¯1M¡¡24¡«380VAC¡¡10A¡¡¡¡¡¡SSR-25VA¡¡25A¡¡¡¡¡¡SSR-40VA¡¡40A¡¡¡¡¡¡SSR-50VA¡¡50A¡¡¡¡¡¡SSR-75VA¡¡75A¡¡
¡¡¡¡µçѹ¿Éµ÷ÐÍ¡¡¸ß¾«¶È¡¡SSR-10VAR¡¡110V£¯250K£¬220V£¯500K£¬380V£¯1M¡¡24¡«380VAC¡¡10A¡¡¡¡¡¡SSR-25VAR¡¡25A¡¡¡¡¡¡SSR-40VAR¡¡40A¡¡
¡¡¡¡Ö±Á÷µçѹ¡¡SSR-05DD¡¡3¡«32VDC¡¡5¡«60VDC¡¡5A¡¡¡¡¡¡SSR-10DD¡¡10A¡¡¡¡¡¡SSR-10DD-H¡¡5¡«200VDC¡¡10A¡¡
¡¡¡¡Ð¡µçÁ÷ÐÍ¡¡SSR-03DA¡¡3¡«32VDC¡¡24¡«380VAC¡¡3A¡¡¡¡¡¡SSR-03DD¡¡5¡«60VDC¡¡3A¡¡
¡¡¡¡2 ÀàÐÍ:Âþ·´ÉäÐÍ,¾µÆ¬·´ÉäÐÍ, ¶ÔÉäÐ͵çÔ´ 12-240VDC£¬24-240VAC ¹¦ºÄ 2VA Êä³ö ¼ÌµçÆ÷ 12-240VDC 24-240VAC £¨ºìÍâÏߣ©£¬1A1B ´¥µãÈÝÁ¿ 3A/250VAC ʱ¼ä 15ms ¹¤×÷»·¾³ -20¡æ££+60¡æ£¬35%-85%RH Íâ¸ÉÈŹâ Èչ⣼10£¬000Lux£»µÆ¹â£¼5£¬000Lux ÐͺЏÐÓ¦¾àÀë Êä³ö ¹¤×÷µçѹ ¹âÔ´ ·À»¤µÈ¼¶ µ÷½Úѡť
Âþ·´ÉäÐÍ A3R-30X ¼ì²â¾àÀë30cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-1MX ¼ì²â¾àÀë100cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-2MX ¼ì²â¾àÀë200cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-30XP ¼ì²â¾àÀë30cm IP67 A3R-1MXP ¼ì²â¾àÀë100cm IP67 A3R-2MXP ¼ì²â¾àÀë200cm IP67
