̨ÍåÑôÃ÷fotek ¹Ì̬¼ÌµçÆ÷ESR-40DA
| Æ·ÅÆ£ºFOTEK/ÑôÃ÷ |
ÐͺţºESR-40DA-H. |
µçÔ´µçѹ(V)£ºAC24-480 |
| Êä³ö·½Ê½£º¹Ì̬ |
ÓÃ;£º£¬ |
ʹÓû·¾³Î¶È(¡æ)£º-20-+70 |
| ²úÆ·ÈÏÖ¤£ºCCC |
¹¦Âʼ̵çÆ÷ESR-40DA-H.
A3RϵÁйâµç¿ª¹Ø
ÀàÐÍ:Âþ·´ÉäÐÍ,¾µÆ¬·´ÉäÐÍ, ¶ÔÉäÐ͵çÔ´ 12-240VDC£¬24-240VAC ¹¦ºÄ 2VA Êä³ö ¼ÌµçÆ÷ 12-240VDC 24-240VAC £¨ºìÍâÏߣ©£¬1A1B ´¥µãÈÝÁ¿ 3A/250VAC ʱ¼ä 15ms ¹¤×÷»·¾³ -20¡æ--+60¡æ£¬35%-85%RH Íâ¸ÉÈŹâ Èչ⣼10£¬000Lux£»µÆ¹â£¼5£¬000Lux ÐͺЏÐÓ¦¾àÀë Êä³ö ¹¤×÷µçѹ ¹âÔ´ ·À»¤µÈ¼¶ µ÷½Úѡť
Âþ·´ÉäÐÍ A3R-30X ¼ì²â¾àÀë30cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-1MX ¼ì²â¾àÀë100cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-2MX ¼ì²â¾àÀë200cm 270°¼ì²â¾àÀë¿Éµ÷Õû A3R-30XP ¼ì²â¾àÀë30cm IP67 A3R-1MXP ¼ì²â¾àÀë100cm IP67 A3R-2MXP ¼ì²â¾àÀë200cm IP67
¾µÆ¬·´Éä A3G-2MR ¼ì²â¾àÀë3m ¼ÌµçÆ÷ 12-240VDC 24-240VAC £¨ºìÍâÏߣ© A3G-2MRS ¼ì²â¾àÀë2m A3G-4MX ¼ì²â¾àÀë4m A3G-2MRP ¼ì²â¾àÀë3m IP67 270°¿Éµ÷Õû A3G-4MXP ¼ì²â¾àÀë4.5m
¶ÔÉäÐÍ A3T-3MX ¼ì²â¾àÀë3m ¼ÌµçÆ÷ 12-240VDC 24-240VAC £¨ºìÍâÏߣ© A3T-10MX ¼ì²â¾àÀë10m A3T-20MX ¼ì²â¾àÀë20m A3T-3MXP ¼ì²â¾àÀë3m IP67 A3T-10MXP ¼ì²â¾àÀë10m IP67 A3T-20MXP ¼ì²â¾àÀë20m IP67 ÁíÓÐ50Ã×,80Ã×,150Ã×.¶ÔÉä¹âµç¿ª¹Ø
M18Ô²ÖùÐ͹âµç¿ª¹Ø
×ÔÓÉÂþ·´ÉäÐÍ
ÐͺÅCDR-10X Êä³ö״̬NO ¸ÐӦλÖÃÕýÃæ ¸ÐÓ¦¾àÀë10cm ¹¤×÷µçѹ10-30VDC ÏûºÄ¹¦ÂÊ25mA max Êä³öÐÎʽNPN & PNP 150mA max 270°¿Éµ÷ CDR-10XB NC CDR-30X NO CDR-30XB NC CDR-30X-V NO ²àÃæ 30cm CDR-30XB-V NC CAR-10X NO ÕýÃæ CAR-10XB NC CAR-10X-V NO ²àÃæ 10cm CAR-10XB-V NC CDR-10X-M12 NO CDR-10XB-M12 NC CDR-30X-M12 NO 30cm CDR-30XB-M12 NC CDR-30X-V-M12 NO ²àÃæ 30cm CDR-30XB-V-M12 NC ¾µÆ¬·´ÉäÐÍ CDM-1MN NO ÕýÃæ 0.1m-1.6m 10-30VDC 20mA max NPN Non CDM-1MR NO ²àÃæ CDM-1MRB NC CDM-2MX NO 0.1m-2.5m CDM-2MXB NC CDM-2MX-V NO ÕýÃæ 0.1m-2.0m CDM-2MXB-V NC CAM-2MX NO CAM-2MXB NC CAN-2MX-V NO ²àÃæ CAM-2MXB-V NC CDM-2MX-M12 NO ÕýÃæ CDM-2MXB-M12 NC CDM-2MX-V-M12 NO ²àÃæ 0.1m-2.0m CDM-2MXB-V-M12 NC MDM-2MX ½ðÊôÍâ¿Ç
¶ÔÉäÐÍ CDT-10MX NO ÕýÃæ 10m 10-30VDC P£¼20mA R£¼25mA NPN & PNP CDT-10MXB NC CDT-6MX-V NO ²àÃæ 6m CDT-6MXB-V NC CDT-10MX-M12 NO ÕýÃæ 10m CDT-10MXB-M12 NC CDT-6MX-V-M12 NO ²àÃæ 6m CDT-6MXB-V-M12 NC ±¸×¢£ºÐͺÅÖдøB±íʾ³£±ÕÊä³ö£¬´øV±íʾ²àÃæ¼ì²â£¬M12±íʾ½Ó¿Ú
³¬Ð¡Ð͹âµç¿ª¹ØNPN Óë PNPË«Êä³ö
Âþ·´ÉäÐÍ: MR-30X ¼ì²â¾àÀë30cm NPN Óë PNPË«Êä³ö 150mA µçѹ10-30VDC LED IP65 270° MR-60X 60cm PR-30X 30cm PR-60X 60cm MR-30XP 30cm IP67 MR-60XP 60cm PR-30XP 30cm PR-60XP 60cm
¾µÆ¬·´Éä: MG-2MX 2m NPN Óë PNPË«Êä³ö 150mA 10-30VDC LED IP65 270° PG-2MX 2m MG-2MXP 2m IP67 PG-2MXP 2m
¶ÔÉäÐÍ: ¡¡ MT-6MX 6m NPN Óë PNP Ë«Êä³ö150mA 10-30VDC LED IP65 270° PT-6MX 6m NPN Óë PNP Ë«Êä³ö150mA 10-30VDC LED IP65 270° MT-6MXP 6m NPN Óë PNP Ë«Êä³ö150mA 10-30VDC LED IP65 270°IP67 PT-6MXP 6m NPN Óë PNP Ë«Êä³ö150mA 10-30VDC LED IP65 270°IP67
ÑôÃ÷¿ØÖÆ
C-1 FR-1 PR-1 PVR-3 C-2,C-6 MF-06R FF-03R FPR-51 FPT-02 SU-07X SU-02X SU-07R MS-02W MS-02W-H MS-02W-M12 MS-02WH-M12 ÑôÃ÷¼ÆÊýÆ÷
SC-341 SC-361 SC-342 SC-352 SC-362 SC-3616 SC-3526 SC-3626 SC-326 SC-262 SC-261 SC-260 SC-2D SC-3D SC-4D H5C-4D SK-2D SK-3D SK-4D HC-4T HC-5T HC-6T HC-21P HC-31P HC-41P HC-51P HC-61P C-3617 C-3427 C-262 C-261 C-260 HC-42P HC-52P HC-4P6T M-30 M-31 M-32 M-20 M-21 M-22 SM-30 SM-20 SM-20 SM-20 SC-362M Êä³ö·½Ê½ ¼ÌµçÆ÷ 5A-250VAC max
̨ÍåÑôÃ÷fotekÐÂÒ»´ú¶à¹¦ÄܼÆÊýÆ÷
ÌØÐÔ: 1.¿ÉµÝÔö,µÝ¼õ¼ÆÊý. 2.СÊýµãÈýλ¿ÉÉ趨0.001-99.999 3.ÏìӦʱ¼ä¿ÉÉ趨0.2ms-9999ms 4.ÏìӦƵÂÊÉ趨0.1HZ-5kHZ 5.Êä³ö¿ØÖÆ·½Ê½É趨¿ÉÑ¡,ÊÖ¶¯¸´Î»,×Ô¶¯¸´Î» 6.Êä³öÏìӦʱ¼äÒ²¿ÉÒÔÉ趨0.01-99.99sec 7.ÁíÓÐË«ÖØÉ趨ºÍ¶þ·Êä³ö
¡øµ¥ÏàÉ趨,һ·Êä³ö: MC-441, MC-461 MC-341 MC-361 MC-261
¡øË«ÏàÉ趨,¶þ·Êä³ö: MC-442, MC-462 MC-342 MC-362 MC-262
̨Íåfotekʱ¼ä¼ÌµçÆ÷ÌØÐÔ:ÐÔÄÜÎȶ¨,¹¤×÷µçѹ 12»ò24VAC/DC »ò 220VAC »ò 380VAC 50/60Hz £¨TMϵÁÐΪ90¡«250VAC£©Êä³ö¼ÌµçÆ÷, ¹¦ºÄ 3VA max ´¥µãÊÙÃü 20 X 106 ´Î
H3-FK-M3 H3-TRD-30S H3-M¡õ H3-¡õ¡õ H2Y-¡õ¡õ H3Y-¡õ¡õ MY-¡õ¡õ H5B-FK-M3 TM48-FK-M3 H5B-M¡õ TM48-M STPY-FK-M3 STPN-FK-M3 STPY-M STPN- TFN- H5B-TF H3-TF-¡¡ TDVN-M TDVY-M TDFN-12H TDFY-12H H5T-4D G4Q-K1 G4Q-K2 SY-2D SY-3D SY-4D STP-2D STP-3D STP-4D H5M-4D SK-2D SK-3D SK-4D PF085A P2CF-08 8PFA P3G-08
´Å»É¿ª¹Ø
ÐͺŠFC-1, FC-2 ,FC-3 ¹¤×÷µçѹ 5-240VAC/DC ¹¦ºÄ 50mA ×î´ó¹¦ÂÊ DC£º8W£¬ AC£º10VA Êä³ö״̬ NO ·´Ó¦Ê±¼ä 1ms ¡¡ 2V max ¡¡ 2M/2Cores ¹¤×÷»·¾³ -10¡æ- +60¡æ£»³£±ÕÊä³ö˵Ã÷ FC-1B £¬ FC-2B £¬ FC-3B £¬ µçѹ5-24VDC £¬ 20mA/2WOnly
µ¥Ïà¹Ì̬¼ÌµçÆ÷ SSR-10DA 3¡«32VDC 24¡«380VAC 10A SSR-25DA 25A SSR-40DA 40A SSR-50DA 50A SSR-75DA 75A SSR-10DA-H 3¡«32VDC 90¡«480VAC 10A SSR-25DA-H 25A SSR-40DA-H 40A SSR-50DA-H 50A SSR-75DA-H 75A µ¥ÏཻÁ÷´¥·¢ SSR-10AA 80¡«250VAC 24¡«380VAC 10A SSR-25AA 25A SSR-40AA 40A SSR-50AA 50A SSR-75AA 75A SSR-10AA-H 80¡«250VAC 90¡«480VAC 10A SSR-25AA-H 25A SSR-40AA-H 40A SSR-50AA-H 50A SSR-75AA-H 75A µçѹ¿Éµ÷ÐÍ SSR-10VA 110V/250K£¬220V/500K£¬380V/1M 24¡«380VAC 10A SSR-25VA 25A SSR-40VA 40A SSR-50VA 50A µçѹ¿Éµ÷ÐÍ ¸ß¾«¶È SSR-10VAR 110V/250K£¬220V/500K£¬380V/1M 24¡«380VAC 10A SSR-25VAR 25A SSR-40VAR 40A Ö±Á÷µçѹ SSR-05DD 3¡«32VDC 5¡«60VDC 5A SSR-10DD 10A SSR-10DD-H 5¡«200VDC 10A СµçÁ÷ÐÍ SSR-03DA 3¡«32VDC 24¡«380VAC 3A SSR-03DD 5¡«60VDC 3A µçÁ÷´¥·¢ÐÍ SSR-25LA 4-20mA 90¡«250VAC 25A SSR-40LA 40A SSR-50LA 50A SSR-75LA 75A SSR-25LA-H 4-20mA 250¡«480VAC 25A SSR-40LA-H 40A SSR-50LA-H 50A SSR-75LA-H 75A
ÈýÏà¹Ì̬¼Ìµç TSR-25DA TSR-40DA TSR-75DA TSR-25DA-H TSR-40DA-H TSR-75DA-H
̨ÍåÑôÃ÷-ζȿØÖÆÆ÷
ÖÇÄÜÐÍ΢µçÄÔζȿØÖÆÆ÷,PID×ÔÕû¶¨.¹¤×÷µçѹ90-250VAC 50/60Hz ¸ÐÎÂÆ÷ K / J / PT-100×ÔÐÐÉ趨¿ØÖÆ·½Ê½ FUZZY+PID»òON/OFF ¹¤×÷»·¾³ -10¡æ-+75¡æ / 25%-85%PH ÏÔʾ¾«¶È £¨0.1%of F.S+1Digit£©ÐͺÅ: ³ß´ç:48x48mm MT48-R,MT48-V,MT48-L MT-48E ³ß´ç:72x72mm MT72-R,MT72-V,MT72-L,MT-72E ³ß´ç:96x96mm MT96-R,MT96-V,MT96-L ,MT-96E ³ß´ç:48x96mm MT20-R,MT20-V ³ß´ç:96x48mm MT21-V MT21-R.
¿ª¹ØÁ¿¿ØÖÆÐÍÎÂ¿ØÆ÷³ß´ç:48x48mm TC-48-AN TC-48-AD TC-48-AD-A TC-48-AD-AH ³ß´ç:72x72mm TC-72-AN TC-72-AA TC-72-AA-A T-72-AA-AH TC-72-AD TC-72-AD-A TC-72-AD-AH ³ß´ç:96x96mm TC-96-AN TC-96-AA TC-96-AA-A TC-96-AA-AH TC-96-AD TC-96-AD-A TC-96-AD-AH
