ÐͺÅ
HR910S
HR910H
HR920S
HR920H
HR930S
HR930H
¶î¶¨ÈÝÁ¿
1KVA/900W
2KVA/1800W
3KVA/2700W
ÊäÈëÊä³ö
µ¥½øµ¥³ö
ÊäÈë
ÀäÆô¶¯
Ö§³Öµç³ØÀäÆô¶¯,ƵÂÊ¿ÉÉèÖÃ,ĬÈÏ50HZ
ÊäÈëµçѹ
50%¡«125%(220VAC/230VAC/240VAC)
100% ¶î¶¨¸ºÔØÊ±,80%¡«125%
85% ¶î¶¨¸ºÔØÊ±,70%¡«125%
75% ¶î¶¨¸ºÔØÊ±,60%¡«125%
60% ¶î¶¨¸ºÔØÊ±,50%¡«125%
µçѹÇл»µã
µÍѹÇл»110VAC
µÍѹ»Ö¸´121VAC
¸ßѹÇл»288VAC
¸ßѹ»Ö¸´281VAC
ÊäÈëµçÁ÷
4.8A
9.6A
14.4A
ÊäÈëÆµÂÊ
40¡«70Hz
¹¦ÂÊÒòÊý
≥0.97
Êä³ö
¶î¶¨µçѹ
220VAC
Êä³ö²¨ÐÎ
´¿¾»ÕýÏÒ²¨
¹¦ÂÊÒòÊý
0.9
µçѹµ÷ÕûÂÊ
±1%
¶¯Ì¬ÏìÓ¦
≤5% (0% - 100% -0%)
¶¯Ì¬»Ö¸´
≤10ms (0% - 100% -0%)
µçÑ¹Ê§Õæ¶È
≤1% THD,ÏßÐÔÔØ
≤5.5% THD, ·ÇÏßÐÔÔØ
≤5% THD, ·ÇÏßÐÔÔØ
≤5% THD,·ÇÏßÐÔÔØ
ƵÂÊ×ÔÊÊÓ¦
¿ÉÉè
¸ú×Ù·¶Î§
±5HzĬÈÏ
¸ú×ÙËÙ¶È
0.5¡«5Hz/s,2 Hz/sĬÈÏ
µç³ØÄ£Ê½
(50±0.1) HzĬÈÏ
µçÁ÷
4.3A
8.6A
13.5A
¹ýÔØÄÜÁ¦
(ÔÚÏßģʽ)
105%¡«130%: 1·ÖÖÓºóÇÐÅÔ·
150%: 30ÃëºóÇÐÅÔ·
¹ýÔØÄÜÁ¦
(µç³ØÄ£Ê½)
105%¡«130%ά³Ö10Ãëºó¹Ø»ú
150%ά³Ö5Ãëºó¹Ø»ú
¹ýÔØÄÜÁ¦
(ÅÔ·ģʽ)
<130%: Õý³£
130%¡«150%:10·ÖÖÓºó¹Ø»ú
150%¡«180%:5ÃëÖÓºó¹Ø»ú
¸ºÔØ·åÖµ±È
3:1£¨Max£©
ϵͳ
Çл»Ê±¼ä
Ö÷·ÇÐµç³Ø0ms
Äæ±äÇÐÅÔ·2ms
EMI/EMC
IEC/EN 62040-2:2006 C3
EMS
IEC/EN 61000-4-2:2009 B (ESD)
IEC/EN 61000-4-3:2006 +A1:2008 +A2:2010 A (RS)
IEC/EN 61000-4-4:2004+A1:2010 B(EFT)
IEC/EN 61000-4-5:2006 B(Surge)
IEC/EN 61000-4-6:2009 A(RF)
IEC/EN 61000-4-8:2010 A(Magnetic Field)
IEC/EN 61000-4-11:2004 A(VD)
IEC/EN 61000-2-2:2002 A(LF)
ЧÂÊ
Ö÷·ģʽ
µç³Ø³äÂú
100%¶î¶¨¸ºÔØÊ±86%
50%¶î¶¨¸ºÔØÊ±87%
100%¶î¶¨¸ºÔØÊ±88%
50%¶î¶¨¸ºÔØÊ±91%
100%¶î¶¨¸ºÔØÊ±88%
50%¶î¶¨¸ºÔØÊ±90%
ECOģʽ
94%
97%
97%
µç³ØÄ£Ê½
100%¶î¶¨¸ºÔØÊ±83%
50%¶î¶¨¸ºÔØÊ±84%
100%¶î¶¨¸ºÔØÊ±87%
50%¶î¶¨¸ºÔØÊ±88%
100%¶î¶¨¸ºÔØÊ±87%
50%¶î¶¨¸ºÔØÊ±89%
ÔëÉù
(ǰ·½1mÔ¶)
<60%¶î¶¨¸ºÔØÊ±<45dB
>60%¶î¶¨¸ºÔØÊ±<50dB
<60%¶î¶¨¸ºÔØÊ±<50dB
>60%¶î¶¨¸ºÔØÊ±<55dB
<60%¶î¶¨¸ºÔØÊ±<50dB
>60%¶î¶¨¸ºÔØÊ±<55dB
µç³Ø
µç³ØÀàÐÍ
ÃÜ·âÃâά»¤Ç¦ËáÐîµç³Ø
ÐͺÅ
12VDC/7Ah
È¡¾öÓÚÍâ½Óµç³Ø
12VDC/7Ah
È¡¾öÓÚÍâ½Óµç³Ø
12VDC/7Ah
È¡¾öÓÚÍâ½Óµç³Ø
ÊýÁ¿
3
6
8
Ö±Á÷µçѹ
36VDC
72VDC
96VDC
ºó±¸Ê±¼ä
80%¸ºÔØÊ±6·ÖÖÓ
È¡¾öÓÚÍâ½Óµç³Ø
80%¸ºÔØÊ±6·ÖÖÓ
È¡¾öÓÚÍâ½Óµç³Ø
80%¸ºÔØÊ±5.5·ÖÖÓ
È¡¾öÓÚÍâ½Óµç³Ø
µç³ØµÍѹ
33VDC¡«35VDC£¬¸ù¾Ý¸ºÔØÂʱ仯
66VDC¡«70VDC£¬¸ù¾Ý¸ºÔØÂʱ仯
88VDC¡«94VDC£¬¸ù¾Ý¸ºÔØÂʱ仯
³äµçÆ÷
³äµçµçѹ
¸¡³ä:41VDC/¾ù³ä:42VDC
¸¡³ä:82VDC/¾ù³ä:84VDC
¸¡³ä:109VDC/¾ù³ä:112VDC
×î´ó³äµçµçÁ÷
1A
4A/8A
1A
4A/8A
1A
4A/8A
³äµçʱ¼ä
8Сʱ³äµ½90%
È¡¾öÓÚÍâ½Óµç³Ø
8Сʱ³äµ½90
È¡¾öÓÚÍâ½Óµç³Ø
8Сʱ³äµ½90%
È¡¾öÓÚÍâ½Óµç³Ø
©µçµçÁ÷
<1mA
ÏÔʾºÍ±¨¾¯
ÏÔʾ
LED+LCD
µç³Ø·Åµç
ÿ¸ô2·ÖÏìÒ»´Î
µç³ØµçѹµÍ
ÿ¸ô6ÃëÏìÒ»´Î
¹ýÔØ
³ÖÐøÏì
ÊäÈëµçѹÒì³££¨°üÀ¨ÏàÐò½Ó·´£¬µØÏßδ½Ó£©
2·ÖÖÓÏìÒ»´Î
±¨¾¯
ÿ¸ô6ÃëÏìÒ»´Î
¹ÊÕÏ
³ÖÐøÏì
½Ó¿Ú
RS232
ͨ¹ý±ê×¼ÏßÀÂÖ§³Öºǫ́Èí¼þ
SNMP(Ñ¡¼þ)
ͨ¹ýÍøÂç¼à¿Ø»úÆ÷
EPO
½ô¼±¹Ø»ú
ÊäÈë
IEC C14
14.4A
Êä³ö
6*IEC C13
14.4A
Ñ¡¼þ
ÖÇÄÜ¿¨
¿É²å°ÎDB9¸É½Óµã¿¨
USB
BÐÍUSB¿Ú
SNMP¿¨
¿É²å°Î
»·¾³
»·¾³Î¶È
0¡«40¡æ
»·¾³Êª¶È
0%¡«95%
º£°Î¸ß¶È
<1500m
·ûºÏ±ê×¼
°²¹æ
EN62040-1
EMC
EN62040-2£¬EN61000-4-2£¬EN61000-4-3£¬EN61000-4-4£¬EN61000-4-5£¬EN61000-4-6
²úÆ·
YD/T1095-2008
ÎïÀíÌØÕ÷
³ß´ç(mm)
(W*D*H)
440*430*86
(2U)
440*430*86
(2U)
440*480*173
(4U)
440*480*86
(2U)
440*480*173
(4U)
440*480*86
(2U)
Íâ°ü³ß´ç(mm)
(W*D*H)
580*565*250
580*565*250
580*660*335
580*615*250
580*660*335
580*615*250
¾»ÖØÁ¿(kg)
12
6
21
10.5
25.6
11.5
Ã«ÖØ(KG)
13
7
22
12
27
13
ÑÕÉ«
ºÚÉ«
