Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¼ÓÄôóNovAtel GNSS½ÓÊÕ»úProPak6 £¨PP6)
²úÆ·Ãû³Æ£º ¼ÓÄôóNovAtel GNSS½ÓÊÕ»úProPak6 £¨PP6)
ÐÍ ºÅ£º ProPak6 £¨PP6)
ProPak6  GNSS½ÓÊÕ»ú
ProPak6ÊÇNovAtel¹«Ë¾×îÐÂÍÆ³öµÄºÍ×îÏȽøµÄGNSS½ÓÊÕ»ú¡£ProPak6ÒÔÁé»îµÄÅäÖÃÂú×ãÄúµÄÐèÇ󣬶¨Î»¾«¶È´Ó¶ÀÁ¢Ã×¼¶µ½ÀåÃ×¼¶¡£ÆäÍâ¿Ç¼á¹Ì,·ÀË®µÈ¼¶IP67£¬¹¤×÷ζȷ¶Î§¿í£¬½Ó¿Ú·á¸»¿ÉÒÔ¸ü¿ìËÙµÄʹ²úƷͶÈëʹÓá£
http://www.sdi-china.com/upload/Image/mrtp/1_2558806438.jpg
Propak6
ÌØµã£º
240¸öͨµÀ
ÀåÃ×¼¶µÄ¶¨Î»¾«¶È
½Ó¿Ú±ê×¼Á¬½ÓÆ÷¼òµ¥
4 GB°åÔØ´æ´¢Êý¾Ý
±ê×¼À¶ÑÀ®ºÍwi – fiÄ£¿é
¿ÉÅäÖÃGPRS/HSPAÎÞÏßͨÐÅÄ£¿é
¿Éѡ˫ÌìÏßÅäÖÃ
¶¨Î»¾«¶È£¨RMS£©
µ¥µãL1
1.5m
µ¥µãL1/L2
1.2m
SBAS
0.6m
DGPS
0.4m
RTK
RTK¾«¶È
1cm+1ppm
RTK³õʼ»¯Ê±¼ä
<10 s
RTK³õʼ»¯×¼È·¶È
>99.9%
ËٶȾ«¶È£¨RMS£©
0.03m/s
ʱ¼ä¾«¶È£¨RMS£©
20ns
½ÓÊÕͨµÀ
240ͨµÀ
ÎÀÐÇϵͳ
GPS L1, L2, L2C, L5
GLONASS L1, L2, L2C
Galileo E1, E5a, E5b, AltBOC
BeiDou B1, B2
SBAS
QZSS L1, L2C, L5
L-Band
²âÁ¿¾«¶È
GPS
GLO
L1 C/AÂë
 4cm
8cm
L1ÔØ²¨Ïàλ
0.5mm
1mm
L2 P£¨Y£©Âë
8cm
8cm
L2ÔØ²¨Ïàλ
1mm
1mm
L2CÂë
8cm
8cm
L2CÔØ²¨Ïàλ
1mm
1mm
L5Âë
3 cm
L5ÔØ²¨Ïàλ
0.5 mm
Æô¶¯Ê±¼ä
ÀäÆô¶¯
50 s
ÈÈÆô¶¯
35 s
Êý¾Ý¸üÐÂÂÊ
λÖÃ
100Hz
²âÁ¿
100Hz
º½Ïò¾«¶È
£¨Ë«ÌìÏßÅäÖã©
0.40°  @0.5 m »ùÏß
0.20°   @1.0 m »ùÏß
0.10°   @2.0 m»ùÏß
ͨѶ½Ó¿Ú
RS-232/RS-422
3
IMU½Ó¿Ú
1
USB2.0Device
1
USB2.0Host
1
Íø¿Ú
1
CAN×ÜÏß
2
EventÊäÈë
4
EventÊä³ö
4
À¶ÑÀ
1
Wi-Fi
1
ÎÞÏßͨѶGPRS/HSPA
¿ÉÑ¡
ÎïÀíµçÆøÖ¸±ê
Ìå»ý
190mm×185mm×75mm
ÖØÁ¿
1.79Kg
¹¦ºÄ
3.5W
ÊäÈëµçѹ
+9V¡«+36V
»·¾³ÊÊÓ¦ÐÔÖ¸±ê
¹¤×÷ζÈ
-40¡æ¡«+75¡æ
´æ´¢Î¶È
-40¡æ¡«+95¡æ
ʪ¶È
95%ÎÞÀäÄý
Õñ¶¯£¨¹¤×÷£©
Ëæ»ú MIL-STD-810 514.6 Category 24, 20-2000Hz/ 7.7 g 1 hr/axis
ÕýÏÒ IEC 60068-2-6 (5 g),10-2000 Hz
¼ÓËÙ¶È£¨¹¤×÷£©
MIL-STD 810G, Method 513.6
Procedure II (16 g)
³å»÷£¨·Ç¹¤×÷£©
MIL-STD-810G, 516.6 , procedure 1,
40 g 11 ms terminal sawtooth
¹«Ë¾Ãû³Æ£º ±±¾©Æßάº½²â¿Æ¼¼¹É·ÝÓÐÏÞ¹«Ë¾
µç »°£º 010 57800988-8019 / ÂíÊçæÂ
ÊÖ»ú£º 15911049663
µØ Ö·£º ±±¾©Êк£µíÇøÎ÷±±Íú¹¤ÒµÔ°ÇøÓÀ½ÝÄÏ·2ºÅÔº2ºÅÂ¥
ÓÊ ±à£º 100094
Ö÷ Ò³£º http://www.sdi-china.com
  • TimeNav ÊÚʱµ¼º½½ÓÊÕ»ú
  • ADL Vantage Pro 35Wµç̨
  • ADL Vantage Êý´«µç̨
  • SDI-COMPASS-T ±±¶·¶¨Î»¶¨ÏòÊÚʱ½ÓÊÕ»ú
  • SDI-201 ±±¶·Ò»Ìåʽ½ÓÊÕ»ú
  • SDI-151Ѱ±±ÒÇ
  • µ¥Öá´ÅÂÞÅÌKVH C100
  • HMR3000ϵÁеç×ÓÂÞÅÌ
  • ¶àϵͳÎÀÐǵ¼º½²â×˲úÆ·Triumph-4x
  • ¸ßÐÔÄÜÃÀ¹úJAVAD¹«Ë¾GPS½ÓÊÕ»úSIGMA
