²úÆ·Ãû³Æ£º
¸ßÐÔÄÜ´ø´æ´¢GNSS½ÓÊÕ»úProPak6
ÐÍ ºÅ£º
ProPak6
ProPak6ÊÇNovAtel¹«Ë¾×îÐÂÍÆ³öµÄºÍ×îÏȽøµÄGNSS½ÓÊÕ»ú¡£ProPak6ÒÔÁé»îµÄÅäÖÃÂú×ãÄúµÄÐèÇ󣬶¨Î»¾«¶È´Ó¶ÀÁ¢Ã×¼¶µ½ÀåÃ×¼¶¡£ÆäÍâ¿Ç¼á¹Ì,·ÀË®µÈ¼¶IP67£¬¹¤×÷ζȷ¶Î§¿í£¬½Ó¿Ú·á¸»¿ÉÒÔ¸ü¿ìËÙµÄʹ²úƷͶÈëʹÓá£
Propak6
ÌØµã£º
240¸öͨµÀ
ÀåÃ×¼¶µÄ¶¨Î»¾«¶È
½Ó¿Ú±ê×¼Á¬½ÓÆ÷¼òµ¥
4 GB°åÔØ´æ´¢Êý¾Ý
±ê×¼À¶ÑÀ®ºÍwi – fiÄ£¿é
¿ÉÅäÖÃGPRS/HSPAÎÞÏßͨÐÅÄ£¿é
¿Éѡ˫ÌìÏßÅäÖÃ
¶¨Î»¾«¶È£¨RMS£©
µ¥µãL1
1.5m
µ¥µãL1/L2
1.2m
SBAS
0.6m
DGPS
0.4m
RTK
RTK¾«¶È
1cm+1ppm
RTK³õʼ»¯Ê±¼ä
<10 s
RTK³õʼ»¯×¼È·¶È
>99.9%
ËٶȾ«¶È£¨RMS£©
0.03m/s
ʱ¼ä¾«¶È£¨RMS£©
20ns
½ÓÊÕͨµÀ
240ͨµÀ
ÎÀÐÇϵͳ
GPS L1, L2, L2C, L5
GLONASS L1, L2, L2C
Galileo E1, E5a, E5b, AltBOC
BeiDou B1, B2
SBAS
QZSS L1, L2C, L5
L-Band
²âÁ¿¾«¶È
GPS
GLO
L1 C/AÂë
4cm
8cm
L1ÔØ²¨Ïàλ
0.5mm
1mm
L2 P£¨Y£©Âë
8cm
8cm
L2ÔØ²¨Ïàλ
1mm
1mm
L2CÂë
8cm
8cm
L2CÔØ²¨Ïàλ
1mm
1mm
L5Âë
3 cm
L5ÔØ²¨Ïàλ
0.5 mm
Æô¶¯Ê±¼ä
ÀäÆô¶¯
50 s
ÈÈÆô¶¯
35 s
Êý¾Ý¸üÐÂÂÊ
λÖÃ
100Hz
²âÁ¿
100Hz
º½Ïò¾«¶È
£¨Ë«ÌìÏßÅäÖã©
0.40° @0.5 m »ùÏß
0.20° @1.0 m »ùÏß
0.10° @2.0 m»ùÏß
ͨѶ½Ó¿Ú
RS-232/RS-422
3
IMU½Ó¿Ú
1
USB2.0Device
1
USB2.0Host
1
Íø¿Ú
1
CAN×ÜÏß
2
EventÊäÈë
4
EventÊä³ö
4
À¶ÑÀ
1
Wi-Fi
1
ÎÞÏßͨѶGPRS/HSPA
¿ÉÑ¡
ÎïÀíµçÆøÖ¸±ê
Ìå»ý
190mm×185mm×75mm
ÖØÁ¿
1.79Kg
¹¦ºÄ
3.5W
ÊäÈëµçѹ
+9V¡«+36V
»·¾³ÊÊÓ¦ÐÔÖ¸±ê
¹¤×÷ζÈ
-40¡æ¡«+75¡æ
´æ´¢Î¶È
-40¡æ¡«+95¡æ
ʪ¶È
95%ÎÞÀäÄý
Õñ¶¯£¨¹¤×÷£©
Ëæ»ú MIL-STD-810 514.6 Category 24, 20-2000Hz/ 7.7 g 1 hr/axis
ÕýÏÒ IEC 60068-2-6 (5 g),10-2000 Hz
¼ÓËÙ¶È£¨¹¤×÷£©
MIL-STD 810G, Method 513.6
Procedure II (16 g)
³å»÷£¨·Ç¹¤×÷£©
MIL-STD-810G, 516.6 , procedure 1,
40 g 11 ms terminal sawtooth
ÈçÓÐÀàËÆÐèÇó£¬ÇëÁªÏµ Æßάº½²â ÂíÊçæÂ
