²úÆ·Ãû³Æ£º
Telemecanique·¨¹úÊ©Ä͵½ӽü¿ª¹ØXS618B1MAL2
ÐÍ ºÅ£º
XS618B1MAL2
Main
Range of product
OsiSense XS
Series name
General purpose
Sensor type
Inductive proximity sensor
Device application
Sensor name
XS6
Sensor design
Cylindrical M18
Size
62 mm
Body type
Fixed
Detector flush mounting acceptance
Flush mountable
Material
Metal
Type of output signal
Discrete
Wiring technique
2-wire
[Sn] nominal sensing distance
8 mm
Discrete output function
1 NO
Output circuit type
AC/DC
Electrical connection
Cable
Cable length
2 m
[Us] rated supply voltage
24...240 V AC/DC (50/60 Hz)
Switching capacity in mA
5...300 mA AC
5...200 mA DC
IP degree of protection
IP69 K conforming to DIN 40050
IP68 double insulation conforming to IEC 60529
Complementary
Thread type
M18 x 1
Detection face
Frontal
Front material
PPS
Enclosure material
Nickel plated brass
Operating zone
0...6.4 mm
Differential travel
1...15% of Sr
Cable composition
2 x 0.34 mm²
Wire insulation material
PvR
Status LED
1 LED (yellow) for output state
Supply voltage limits
20...264 V AC/DC
Residual current
≤0.8 mA, open state
Switching frequency
≤ 25 Hz AC
≤1000 Hz DC
Voltage drop
≤5.5 V, closed state
Delay first up
≤25 ms
Delay response
≤0.5 ms
Delay recovery
≤ 0.5 ms
Marking
CE
Threaded length
52 mm
Length
62 mm
Product weight
0.12 kg
Environment
Product certifications
CSA
UL
Ambient air temperature for operation
-25...70 °C
Ambient air temperature for storage
-40...85 °C
