²úÆ·Ãû³Æ£º
°îÄɼ¤¹â²â¾à´«¸ÐÆ÷Q4XTBLAF300-Q8
ÐÍ ºÅ£º
Q4XTBLAF300-Q8
Specifications
Sensing Mode (General)
Proximity
Sensing Mode (Specific)
Background Suppression (Adjustable)
Sensing Beam Wavelength
655
Laser Classification
Class 1
Max Sensing Range [mm]
300
Supply Voltage
10-30 V dc
Output Type
Bipolar (NPN & PNP)
Operation
Light/Dark Operate
Output response time [ms]
1.5
Delay at Power-up [ms]
750
Connection
Integral QD
Number of Pins
5
IP Rating
IP67, IP68, IP69K
Min Op. Temperature [¡æ]
-10
Max Op. Temperature [¡æ]
55
Max Op. Relative Humidity [%]
95% @ 55¡æ
Basic Housing Material
Stainless Steel
Housing Style
Rectangular with M18 Barrel
Lens Material
Acrylic
Adjustments
Teach Button
Barrel Diameter [mm]
18
