°îÄÉÂþ·´Éäʽ¹âµç´«¸ÐÆ÷S18-2VPDL-Q3
Specifications
Sensing Mode (General)
Proximity
Sensing Mode (Specific)
Diffuse
Sensing Beam Wavelength
624
Max Sensing Range [mm]
750
Supply Voltage
10-30 V dc
Output Type
PNP
Operation
Light/Dark Operate
Output response time [ms]
1.5
Delay at Power-up [ms]
100
Repeatability (µs)
100
Connection
Pigtail QD
Number of Pins
4
IP Rating
IP67
Min Op. Temperature [°C]
-40
Max Op. Temperature [°C]
70
Max Op. Relative Humidity [%]
95% @ 50°C
Basic Housing Material
Thermoplastic
Housing Style
Barrel
Lens Material
Acrylic
Adjustments
Potentiometer
Barrel Diameter [mm]
18
