²úÆ·Ãû³Æ£º
KTM-WN11181PÉ«±ê´«¸ÐÆ÷
ÐÍ ºÅ£º
KTM-WN11181P
Features
Sensing distance:
12.5 mm
Sensing distance tolerance:
± 3 mm
Light source 1):
LED
Wave length:
470 nm, 525 nm, 625 nm
Light spot size:
1.5 mm x 6.5 mm
Light spot direction 2):
Vertical
Output function:
Light/dark switching
Max. web speed tech-in (dynamic):
1 m/s 3)
Type of light:
Blue LED, LED, green, LED, red
Dimensions (W x H x D):
21 mm x 31.5 mm x 12 mm
Housing design (light emission):
Rectangular
Teach-in mode:
2-point teach-in static/dynamic + proximity to mark
Mechanics/electronics
Ripple 1):
≤ 5 Vpp
Power consumption 2):
< 50 mA
Switching frequency 3):
15 kHz
Response time 4):
35 µs
Jitter:
15 µs
Output type:
NPN: HIGH = approx. VS / LOW ≤ 2 V
Switching mode:
NPN
Input, teach-in (ET):
NPN: Teach: U < 2 V, Run: UV- 2 V or open
Retention time (ET):
28 ms, non-volatile memory
Connection type:
Connector M8, 4-pin
Protection class:
III
Circuit protection:
Output Q short-circuit protected, Interference pulse suppression, UV connections, reverse polarity protected
Enclosure rating:
IP 67, IP 67
Weight:
20 g
Housing material:
ABS, Plastic
Output current Imax.:
50 mA 5)
Supply voltage:
12 V DC ... 24 V DC
Ambient data
Shock load:
According to IEC 60068
UL File No.:
NRKH.E348498 & NRKH7.E348498
Ambient operating temperature:
-10 °C ... +55 °C
Ambient storage temperature:
-20 °C ... +75 °C
