²úÆ·Ãû³Æ£º
WLL170-2P132¹âÏË´«¸ÐÆ÷
ÐÍ ºÅ£º
WLL170-2P132
Features
Dimensions (W x H x D):
10.5 mm x 35.5 mm x 83.7 mm
Sensing range max.:
0 mm ... 4,000 mm, through-beam system 1)
Sensing range:
0 mm ... 160 mm, proximity system, 0 mm ... 700 mm, through-beam system 2) 3) 4)
Light source:
LED 5)
Type of light:
Visible red light
Wave length:
660 nm
Adjustment:
Potentiometer, 10-turn 6)
Time type:
Off-delayed
Delay time:
Selectable by sliding switch: ≥40 ms
Indication:
LED
Sensor/detection principle:
Fiber-optic photoelectric sensor
Angle of dispersion:
Ca. 65 °
Housing design (light emission):
Rectangular
Focus:
See LL3 fiber-optic data
Mechanics/electronics
Enclosure rating:
IP 66 1)
Supply voltage:
10 V DC ... 30 V DC 2)
Ripple:
10 % 3)
Power consumption:
≤ 30 mA 4)
Output type:
PNP, open collector
Output current Imax.:
≤ 100 mA
Response time:
≤ 0.25 ms 5)
Switching frequency:
2,000 Hz 6)
Connection type:
Cable, 3-wire, 2 m 7)
Cable material:
PVC
Conductor cross-section:
0.2 mm²
Protection class:
III
Circuit protection:
A, B, C, D 8) 9) 10) 11)
Housing material:
ABS/PC, Plastic
Ambient operating temperature:
-25 °C ... +55 °C
Ambient storage temperature:
-40 °C ... +70 °C
Weight:
Ca. 70 g
Cable diameter:
3.8 mm
Switching mode:
Light/dark switching
Switching mode selector:
Selectable via light/dark selector
UL File No.:
NRNT2.E128350 & NRNT8.E128350
