´øÓÐÊý×ÖI/OÏßµÄNI XϵÁмÆÊýÆ÷/¶¨Ê±Æ÷
- ʼþ¼ÆÊý¡¢ÖÜÆÚ/ƵÂÊ¡¢±àÂëÆ÷¶¨Î»¡¢Âö³å¿í¶È²âÁ¿¡¢Âö³åÉú³É
- 8¸ö32λ¼ÆÊýÆ÷/¼ÆÊ±Æ÷ºÍ40ÌõË«ÏòÊý×ÖI/OÏß
- ÓÃÓÚÿ¸ö¼ÆÊýÆ÷/¶¨Ê±Æ÷µÄDMA¿ØÖÆÆ÷
- ×î´óԴƵÂÊΪ100 MHz£»ÍⲿԴƵÂÊΪ80 MHz
- ²ÉÓÃNI-DAQmxÇý¶¯Èí¼þʵÏÖ×î¸ßÉú²úЧÂʺÍÐÔÄÜ
- XϵÁÐNI-STC3¶¨Ê±Ð¾Æ¬£¬ÊµÏÖÏȽøµÄ´¥·¢ºÍͬ²½¹¦ÄÜ
- ÅäÖÃÍêÕûµÄPXIϵͳ
¸ÅÀÀ£º
NI PXIe-6612ÊÇÒ»¿î¶¨Ê±ºÍÊý×ÖI / OÄ£¿é£¬ÅäÓÐ8¸ö32λ¼ÆÊýÆ÷/¶¨Ê±Æ÷ºÍ40Ìõ¼æÈÝTTL/ CMOSµÄÊý×ÖI / OÏß¡£Äú¿ÉÒÔʹÓÃNI PXIe-6612½øÐи÷ÖÖ¼ÆÊýÆ÷/¶¨Ê±Æ÷ÈÎÎñ£¬°üÀ¨±àÂëÆ÷¶¨Î»²âÁ¿¡¢Ê¼þ¼ÆÊý¡¢ÖÜÆÚ²âÁ¿¡¢Âö³å¿í¶È²âÁ¿¡¢Âö³åÉú³É¡¢Âö³åÐòÁÐÉú³É¡¢°ëÖÜÆÚ²âÁ¿¡¢Ë«±ßÑØ¼ä¸ô²âÁ¿ºÍƵÂʲâÁ¿¡£
¹æ·¶¸ÅÒª£º
¹æ·¶¸ÅÒª
General
Product Family
¼ÆÊýÆ÷ / ¶¨Ê±Æ÷ |
Measurement Type
Êý×Ö
Õý½»±àÂëÆ÷
ƵÂÊ |
Form Factor
PXI / PXI Express |
PXI Bus Type
PXI Express |
Module Width
1 |
RoHS Compliant
ÊÇ |
Isolation Type
None |
Ä£ÄâÊäÈë
µ¥¶ËͨµÀ
0 |
²î·ÖͨµÀ
0 |
Ä£ÄâÊä³ö
Number of Channels
0 |
Digital I / O
Bidirectional Channels
40 |
Input-Only Channels
0 |
Output-Only Channels
0 |
Timing
Ó²¼þ
Èí¼þ |
Clocked Lines
32 |
Maximum Clock Rate
10 MHz |
Logic Levels
TTL |
Programmable Input Filters
ÊÇ |
Supports Programmable Power-Up States?
·ñ |
Digital Input
Maximum Voltage Range
0 V - 5 V |
Digital Output
Current Drive Single
6 mA |
0 V - 5 V |
Counters / Timers
Watchdog Timer
·ñ |
Counters
8 |
Number of DMA Channels
8 |
Buffered Operations
ÊÇ |
Debouncing / Glitch Removal
ÊÇ |
Max Source Frequency
80 MHz |
Pulse Generation
ÊÇ |
Size
32 bits |
Timebase Stability
50 ppm |
Logic Levels
TTL |
Timing / Triggering / Synchronization
Triggering
External Trigger
Êý×Ö |
Synchronization Bus(RTSI)
No |
Ïêϸѯ¼Û¼°ÆäËû·þÎñ²éѯÇëµÇ¼£º
http://sine.ni.com/nips/cds/view/p/lang/zhs/nid/211875
