Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 502-3200-918/É䯵µ¼ÄÉҺλ¿ª¹Ø/ÃÀ¹úDE
²úÆ·Ãû³Æ£º 502-3200-918/É䯵µ¼ÄÉҺλ¿ª¹Ø/ÃÀ¹úDE
ÐÍ ºÅ£º 502-3200-918
Æ· ÅÆ£º ametek-drexelbrook
502-3200-918 | É䯵µ¼ÄÉҺλ¿ª¹Ø | ÃÀ¹úDE
502-3200-918 | É䯵µ¼ÄÉҺλ¿ª¹Ø | ÃÀ¹úDE£¬²úÆ·ÊÇÃÀ¹úAMETEK DE¹«Ë¾ 502--3X00 Z-tron II ϵÁÐÉ䯵µ¼ÄÉҺλ¿ª¹Ø,ÏÖ²úÆ·ÒÑÉý¼¶ÎªZ-tron IV Z4-1002-701 É䯵µ¼ÄÉҺλ¿ª¹Ø
Z-tron IV ϵÁÐÁÏλ¼Æ³£ÓÃÐͺţº
Z4-3001-753¡¢Z4-3001-101¡¢Z4-3001-762¡¢Z4-3501-766¡¢Z4-3001-701
Z4-1001-753¡¢Z4-1001-101¡¢Z4-1001-762¡¢Z4-1501-766¡¢Z4-1001-701
¼¼ÊõÖ¸±ê£º
Power Requirements:
AC Units - Field Adjustable:
95-145 VAC 50/60 Hz 2 Watt
215-265 VAC 50/60 Hz 2 Watt
DC Units:
24 VDC Unit: 19-29 VDC input 2 Watt
Sensitivity:
0.3pF&nbs******bsp;less
Operating Point Range:
0 - 80 pF (20 Turn Pot / 4 pF per Turn)
Extended range with external pad capacitor Pad ratio 1:1
Load Resistance:
Center to Ground 1500 Ohms
Center to Shield 750 Ohms
Shield to Ground 750 Ohms
Failsafe:
Field adjustable to either High-Level Fail-Safe (HLFS)
or
Low-Level Fail-Safe (LLFS)
Output:
DPDT relay closure
Contact Rating:
5A @ 120 Vac non-inductive
2A @ 230 Vac non-inductive
Ambient Temperature:
-40°F to 145°F (-40°C to 63°C)
Temperature Effect:
0.5pF/50°F
Line Voltage Effect:
0.2pF/20V @ 120 Vac
Stability:
0.15pF/6 mo. maximum shift
Spark Protection:
100 Amp
Mounting: (Probe Dependant)
?-inch NPT (Typical)
Housing:
The standard housing meets the following classifications:
Nema 1 General-Purpose
Nema 2 Drip-Tight
Nema 3 Weather-Resistant
Nema 4 Waterproof
Nema 5 Dust-Tight
Nema 12 Industrial Use
FM approval on housing only. If agency approval is required use the Drexelbrook PXL The Point? instrument for point level control.
Time Delay:
0-60 seconds (3/4 Turn Pot) 270° Potentiometer
Approvals
FM / FMC 3810 General Purpose (Pending)
¹«Ë¾Ãû³Æ£º Ìì½òÊÐÌ©¿ÆÊ±´ú²â¿Ø¼¼ÊõÓÐÏÞ¹«Ë¾
µç »°£º 022 23796807 / Íõ¾­Àí
ÊÖ»ú£º 13516137444
µØ Ö·£º Ìì½òÊÐÎ÷ÇàÇøêØÏ¼Â·51ºÅ
ÓÊ ±à£º 300090
Ö÷ Ò³£º http://
  • ¸ßÎÂÐÍÉ䯵µ¼ÄÉÁÏλ¼Æ/Z4-1602-766/L=600mm CSL=450mm/AMETEK DE
  • Z4-1002-N/É䯵µ¼ÄÉÁÏλ¼Æ/ÃÀ¹úAMETEK DE
  • AMETEK DE 508-46-918 ÓÍË®½çÃæÒÇ£¨µçÍѹÞÓã©
  • 502-3200-918/É䯵µ¼ÄÉҺλ¿ª¹Ø/ÃÀ¹úDE
  • Techstar/Ì©¿ÆÊ±´ú-Îïλ¼Æ¡¢ÁÏλ¼Æ
  • TKSD02-3300-907 É䯵µ¼ÄÉÁÏλ¼Æ
  • Z4-3001-753 ÃÀ¹úAMETEK DEÁÏλ¼Æ
  • AMETEK DE ²úÆ·
  • AMETEK DREXELBROOKÁÏλ¼Æ/°¢ÃÀÌØ¿ËÁÏλ¼Æ/ÃÀ¹úDEÁÏλ¼Æ
  • TKSD07 Òô²æÁÏλ¿ª¹Ø-Techstar/Ì©¿ÆÊ±´ú ²úÆ·
