ÏêÇé½éÉÜ£º
Z4-1602-766 ¸ßÎÂÐÍÁÏλ¼Æ-AMETEK DE ÁÏλ¼Æ¡¢°¢ÃÀÌØ¿Ë ÁÏλ¼Æ
AMETEK DE Z4-1601-766-BIB Ƶµ¼ÄÉÁÏλ¼Æ-AMETEK Drexelbrook-ÁÏλ¼Æ²úÆ·
AMETEK DE Z4-1601-766 É䯵µ¼ÄÉÁÏλ¼Æ-°¢ÃÀÌØ¿ËDEÁÏλ¼Æ
AMETEK DE Z-Tron IV ϵÁÐÁÏλ¼ÆÔÀí
É䯵µ¼ÄÉÊÇÒ»ÖÖ´ÓµçÈÝʽ·¢Õ¹ÆðÀ´µÄ¡¢·À¹ÒÁÏ¡¢¸ü¿É¿¿¡¢¸ü׼ȷ¡¢ÊÊÓÃÐÔ¸ü¹ãµÄÁÏλ¿ØÖƼ¼ Êõ£¬É䯵µ¼ÄÉÖе¼Äɵĺ¬ÒåΪµçѧÖÐ×迹µÄµ¹Êý£¬ËüÓɵç×èÐԳɷ֡¢µçÈÝÐԳɷ֡¢¸ÐÐÔ³É·Ö ×ۺ϶ø³É£¬¶øÉ䯵¼´ 100KHZ ÎÞÏߵ粨Æ×£¬ËùÒÔÉ䯵µ¼ÄÉ¿ÉÒÔÀí½âΪÓà 100KHZ ÎÞÏߵ粨 ²âÁ¿µ¼ÄÉ
ÃÀ¹úAMETEK Drexelbrook Z-tron IV Z4ϵÁÐÁÏλ¼Æ ³£ÓÃÐͺţº
Z4-3002-753 AMETEK Drexelbrook ÁÏλ¼Æ
Z4-3002-101 AMETEK Drexelbrook ÁÏλ¼Æ
Z4-3002-762 »Ò¶·ÁÏλ¼Æ
Z4-3502-766 ¸ßÎÂÐÍÁÏλ¼Æ
Z4-3002-701 ·À¸¯ÁÏλ¼Æ
Z4-1002-753 ²Ö±ÃÁÏλ¼Æ
Z4-1002-101 AMETEK DE ÁÏλ¼Æ
Z4-1002-762 ³ý³¾Æ÷ÁÏλ¼Æ
Z4-1502-766 ¸ßÎÂʡúÆ÷ÁÏλ¼Æ
Z4-1002-701 ·À¸¯ÐÍÁÏλ¼Æ
ÃÀ¹ú AMETEK DE Z4ÁÏλ¼Æ°²×°ËµÃ÷
ÇëÓû§°´ÕÕ±¾ËµÃ÷ÊéÖеݲװ¹æ·¶½øÐа²×°£º¸ù¾ÝÏÖ³¡Çé¿öµÄ²»Í¬¿É·Ö ΪÕûÌå°²×°ºÍ·ÖÌå°²×°¡£Ò»°ã²ÉÓÃÔÚ¹Þ¶¥´¹Ö±°²×°µÄ·½Ê½£¬ÔÚ²âÁ¿·Çµ¼µçÎïÁϽé ÖÊʱ£¬Ò²¿ÉÒÔ²ÉÓòà±Úºá×°»òбװ¡£µ±²ÉÓòàװʱ£¬Ê¹ÒDZíÏòÏÂÇãб 30 ¶È°²×°¡£¸ù¾Ý°²×°·½Ê½²»Í¬£¬ÓÖ¿ÉÒÔ·ÖΪ°²×°×ù°²×°ºÍ·¨À¼°²×°¡£
Z4-1601-766-BIB ¸ßÎÂÐÍÁÏλ¼Æ-AMETEK DREXELBROOK
AMETEK DE Z-Tron IV É䯵µ¼ÄÉÁÏλ¼Æ ¼¼ÊõÖ¸±ê£º
Power Requirements:
AC Units - Field Adjustable:
95-145 VAC 50/60 Hz 2 Watt
215-265 VAC 50/60 Hz 2 Watt
DC Units:
24 VDC Unit: 19-29 VDC input 2 Watt
Sensitivity:
0.3pF&nbs******bsp;less
Operating Point Range:
0 - 80 pF (20 Turn Pot / 4 pF per Turn)
Extended range with external pad capacitor Pad ratio 1:1
Load Resistance:
Center to Ground 1500 Ohms
Center to Shield 750 Ohms
Shield to Ground 750 Ohms
Failsafe:
Field adjustable to either High-Level Fail-Safe (HLFS)
or
Low-Level Fail-Safe (LLFS)
Output:
DPDT relay closure
Contact Rating:
*** @ 120 Vac non-inductive
2A @ 230 Vac non-inductive
Ambient Temperature:
-40°F to 145°F (-40°C to 63°C)
Temperature Effect:
0.5pF/50°F
Line Voltage Effect:
0.2pF/20V @ 120 Vac
Stability:
0.15pF/6 mo. maximum shift
Spark Protection:
100 Amp
Mounting: (Probe Dependant)
-inch NPT (Typical)
Housing:
The standard housing meets the following classifications:
Nema 1 General-Purpose
Nema 2 Drip-Tight
Nema 3 Weather-Resistant
Nema 4 Waterproof
Nema 5 Dust-Tight
Nema 12 Industrial Use
FM approval on housing only. If agency approval is required use the Drexelbrook PXL The Point? instrument for point level control.
Time Delay:
0-60 seconds (3/4 Turn Pot) 270° Potentiometer
Approvals
FM / FMC 3810 General Purpose (Pending)
