产品介绍: |
- EMC电磁兼容
- 齐平式或非齐平式安装
- PNP输出
- 感应距离可调校
- 常开/常闭输出功能
- 短路保护(脉冲式)
- 塑料外壳,带M18x1mm细螺纹
- 电缆或插头
- 防护等级IP67
- LED状态指示灯
| Model Name |
Part Number |
Switching output |
Connection type |
Installation in metal |
Max. sensing range |
CM18-08BNP-TW0 |
6026194 |
NPN |
Cable, PVC, 2 m |
Flush |
8 mm |
CM18-08BPP-TW0 |
6026195 |
PNP |
Cable, PVC, 2 m |
Flush |
8 mm |
CM18-08BNP-KC1 |
6021456 |
NPN |
Connector, M12, 4-pin |
Flush |
8 mm |
CM18-08BNP-KW1 |
6021455 |
NPN |
Cable, PVC, 2 m |
Flush |
8 mm |
CM18-08BPP-KC1 |
6020388 |
PNP |
Flush |
8 mm |
CM18-08BPP-KW1 |
6020136 |
PNP |
Cable, PVC, 2 m |
Flush |
8 mm |
CM18-12NNP-KC1 |
6021458 |
NPN |
Non-flush |
12 mm |
CM18-12NNP-KW1 |
6021457 |
NPN |
Cable, PVC, 2 m |
Non-flush |
12 mm |
CM18-12NPP-KC1 |
6020410 |
PNP |
Non-flush |
12 mm |
CM18-12NPP-KW1 |
6020389 |
PNP |
Cable, PVC, 2 m |
Non-flush |
12 mm |
