产品介绍: |
- 激光LED,可见红色光源,2级
- 检测器便于用户使用,易于对准和设置
- 高精度背景遮蔽功能
- 通过旋转开关设置
- 可选择亮通/暗通开关输出
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WTB190TL-N162 |
6026543 |
15 x 44,4 x 30 mm |
Cable, PVC, 2 m |
25 ... 310 mm |
WTB190TL-N460 |
6026544 |
15 x 44,4 x 30 mm |
Connector, M8, 4-pin |
25 ... 310 mm |
WTB190TL-P162 |
6026545 |
15 x 44,4 x 30 mm |
Cable, PVC, 2 m |
25 ... 310 mm |
WTB190TL-P460 |
6026546 |
15 x 44,4 x 30 mm |
25 ... 310 mm |
WTB190TL-N132 |
6026539 |
15 x 44,4 x 30 mm |
Cable, 2 m |
25 ... 105 mm |
WTB190TL-N430 |
6026540 |
15 x 44,4 x 30 mm |
25 ... 105 mm |
WTB190TL-P132 |
6026541 |
15 x 44,4 x 30 mm |
Cable, 2 m |
25 ... 105 mm |
WTB190TL-P430 |
6026542 |
15 x 44,4 x 30 mm |
25 ... 105 mm | |
