产品介绍: |
- 光点聚焦成如激光光点一样
- 细小,适用于精确检测细小物体
- 不受各种背景物干扰
- 坚固外壳,加装了金属套
- 筒在M3螺丝安装孔,以增强坚固性
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WT2S-N111 |
1022662 |
7,6 x 20,6 x 12,5 mm |
Cable, 2 m |
1 ... 15 mm |
WT2S-N131 |
1022663 |
Cable, 2 m |
1 ... 30 mm |
WT2S-P111 |
1022660 |
Cable, 2 m |
1 ... 15 mm |
WT2S-P131 |
1022661 |
Cable, 2 m |
1 ... 30 mm |
WT2S-P211 |
1022658 |
Cable with plug, M8, 3-pin, 200 mm |
1 ... 15 mm |
WT2S-P231 |
1022659 |
1 ... 30 mm |
WT2S-P411 |
1023631 |
Cable with plug, M8, 4-pin, 200 mm |
1 ... 15 mm |
WT2S-P431 |
1023632 |
1 ... 30 mm |
WT2S-F131 |
1025682 |
Cable, 2 m |
1 ... 30 mm |
WT2S-F211 |
1024171 |
1 ... 15 mm | |
