产品名称: 施克 漫反射式光电开关 背景遮蔽BGS WT4-3(迷你型)
型  号: WT4-3(迷你型)
  • 可调校的高精度北京遮蔽功能
  • 不受周围光源干扰(如HF高频光和闪烁的报警灯)
  • 两传感器即使对面安装仍能可靠工作
  • 工作温度为-40...600C
  • 快速的响应时间
Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
WTB4-3P1362 1028081 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3P2162 1028084 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3P2262 1028085 16 x 32 x 12 mm Connector, M8, 4-pin 4 ... 150 mm
WTB4-3P2264 1028086 16 x 32 x 12 mm Connector, M8, 4-pin 4 ... 150 mm
WTB4-3P3162 1028082 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTB4-3N1362 1028087 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3N1164 1028090 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3N2162 1028088 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3N3162 1028089 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTB4-3N1161 1028102 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3N1361 1028101 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3N2161 1028104 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3N3161 1028103 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTB4-3P1161 1028096 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3P1361 1028094 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3P2161 1028099 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3P2261 1028100 16 x 32 x 12 mm Connector, M8, 4-pin 4 ... 150 mm
WTB4-3P3261 1028098 16 x 32 x 12 mm Cable with plug, M8, 4-pin, 100 mm 4 ... 150 mm
WTB4-3N1361 1028108 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3E2161 1028110 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3E3161 1028109 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTB4-3F1361 1028105 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3F2161 1028107 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3F3161 1028106 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTV4-3N1341 1028115 16 x 32 x 12 mm Cable, 2 m 4 ... 50 mm
WTV4-3N2181 1028116 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 50 mm
WTV4-3P1341 1028111 16 x 32 x 12 mm Cable, 2 m 4 ... 50 mm
WTV4-3P2181 1028113 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 50 mm
WTV4-3P2241 1028114 16 x 32 x 12 mm Connector, M8, 4-pin 4 ... 50 mm
WTB4-3P3161 1028097 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTV4-3P3441 1029582 16 x 32 x 12 mm Cable with plug, M12, 4-pin, 150 mm 4 ... 50 mm
WTB4-3N1371 1028125 16 x 32 x 12 mm Cable, 2 m 4 ... 150 mm
WTB4-3P2171 1028123 16 x 32 x 12 mm Connector, M8, 3-pin 4 ... 150 mm
WTB4-3P3171 1028122 16 x 32 x 12 mm Cable with plug, M8, 3-pin, 100 mm 4 ... 150 mm
WTB4T-3N1264 1028092 22 x 42 x 22 mm Cable, 5 m 4 ... 120 mm
WTB4T-3P1264 1028091 22 x 42 x 22 mm Cable, 5 m 4 ... 120 mm
WTV4-3P3141 1028112 16 x 32 x 12 mm Cable with plug, M8, 3-pin 4 ... 50 mm
关 键 词: 施克 漫反射式光电开关
公司名称: 广东西克智能科技有限公司
联 系 人: 广东西克智能科技有限公司
电  话: 020-28823600
手  机:
地  址: 广州市天河区珠江西路15号珠江城大厦18楼
邮  编: 510623
一维码阅读器CLV602
西克新品|VMS6200(VMS6200)
西克 安全位置开关-I1(I10-PA213)
西克 通道防护系统-Sa(Safe Entry Exit)
西克 Visionary
SICK新一代高速分体式(高速分体式3D相机Ranger3)
西克 CFP——最百搭的(CFP——最百搭的液位传感器)
西克酷炫3D科技—TOF(TOF 3D相机)
西克 ATM60绝对值型( ATM60)
IMF 卫生型接近传感器(IMF 卫生型)
G6 迷你型光电传感器(G6 迷你型)
W2S-2 迷你型光电传(W2S-2 迷你型)
IQ40 方形接近传感器(IQ40)
Lector63x 二维(Lector63x)
LMS141 紧凑型激光(LMS141)
DBV50 Core 测(DBV50 Core)
UD18 超声波传感器(UD18)
H18 SureSens(H18)
IO-Link Mast(IO-Link Master)
3Vistor-P CV(3Vistor-P CV)
