产品介绍: |
- LED红色发射光、辅助对位
- 开关频率为800/s
- 输出短路保护
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WL9-2N131 |
1018286 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 4 m |
WL9-2N431 |
1018288 |
12 x 40 x 22 mm |
Connector, M12, 4-pin |
0 ... 4 m |
WL9-2P131 |
1018285 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 4 m |
WL9-2P331 |
1019025 |
12 x 40 x 22 mm |
Connector, M8, 4-pin |
0 ... 4 m |
WL9-2P431 |
1018287 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2P481 |
1022299 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2P631 |
1019269 |
12 x 40 x 22 mm |
Cable with plug, M12, 4-pin, 120 mm |
0 ... 4 m |
WL9-2N121 |
1018290 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 0,4 m |
WL9-2N421 |
1018292 |
12 x 40 x 22 mm |
0 ... 0,4 m |
WL9-2P121 |
1018289 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 0,4 m |
WL9-2P321 |
1019270 |
12 x 40 x 22 mm |
0 ... 0,4 m |
WL9-2P421 |
1018291 |
12 x 40 x 22 mm |
0 ... 0,4 m |
WL9-2P621 |
1019271 |
12 x 40 x 22 mm |
0 ... 0,4 m |
WL9-2N130 |
1018282 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 4 m |
WL9-2N330 |
1019511 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2N430 |
1018284 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2P130 |
1018281 |
12 x 40 x 22 mm |
Cable, 2 m |
0 ... 4 m |
WL9-2P330 |
1019024 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2P430 |
1018283 |
12 x 40 x 22 mm |
0 ... 4 m |
WL9-2P630 |
1019268 |
12 x 40 x 22 mm |
0 ... 4 m | |
