产品介绍: |
- 红色光源
- 可屏蔽周围环境光源
- 可旋转900的M12插头或2m电缆
- 灵敏度,可调较
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WL12-2N120 |
1016084 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 2 m |
WL12-2N130 |
1016085 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 7 m |
WL12-2N420 |
1016091 |
15 x 49 x 41,5 mm |
Connector, M12, 4-pin |
0 ... 2 m |
WL12-2N430 |
1016092 |
15 x 49 x 41,5 mm |
0 ... 7 m |
WL12-2P120 |
1016095 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 2 m |
WL12-2P130 |
1016096 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 7 m |
WL12-2P420 |
1016101 |
15 x 49 x 41,5 mm |
0 ... 2 m |
WL12-2P430 |
1016102 |
15 x 49 x 41,5 mm |
0 ... 7 m |
WL12-2Z430 |
1016108 |
15 x 49 x 41,5 mm |
0 ... 7 m |
WL12G-N530 |
1016309 |
15 x 49 x 41,5 mm |
Connector, M12, 5-pin |
0 ... 3 m |
WL12G-P510 |
1016738 |
15 x 49 x 41,5 mm |
0 ... 3 m |
WL12G-P530 |
1016289 |
15 x 49 x 41,5 mm |
0 ... 3 m |
WL12G-V530 |
1016310 |
15 x 49 x 41,5 mm |
0 ... 3 m |
WL12G-W530 |
1016311 |
15 x 49 x 41,5 mm |
0 ... 3 m |
WL12-2B560 |
1016080 |
15 x 49 x 41,5 mm |
0 ... 4 m |
WL12-2N730 |
1016088 |
15 x 49 x 41,5 mm |
Cable, 3 m |
0 ... 7 m |
WL12-2P730 |
1016098 |
15 x 49 x 41,5 mm |
Cable, 3 m |
0 ... 7 m |
WL12-2N180 |
1016089 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 7 m |
WL12-2N190 |
1016090 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 2 m |
WL12-2N480 |
1016093 |
15 x 49 x 41,5 mm |
0 ... 7 m |
WL12-2N490 |
1016094 |
15 x 49 x 41,5 mm |
0 ... 2 m |
WL12-2P180 |
1016099 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 7 m |
WL12-2P190 |
1016100 |
15 x 49 x 41,5 mm |
Cable, 2 m |
0 ... 2 m |
WL12-2P480 |
1016106 |
15 x 49 x 41,5 mm |
0 ... 7 m |
WL12-2P490 |
1016107 |
15 x 49 x 41,5 mm |
0 ... 2 m |
WL12-2P460 |
1016105 |
15 x 49 x 41,5 mm |
0 ... 4 m | |
Model Name |
Part Number |
Connection type |
WL11-N130 |
1018681 |
15,2 x 51 x 43,5 mm |
Cable, 2 m |
0 ... 7 m |
WL11-N430 |
1018682 |
0 ... 7 m |
WL11-P130 |
1018680 |
Cable, 2 m |
0 ... 7 m |
WL11-P430 |
1018510 |
0 ... 7 m |
WL11-B560 |
1019704 |
0 ... 4 m |
WL11-R130 |
1026232 |
15,2 x 51 x 47 mm |
Cable, 2 m |
0,1 ... 7 m | |
