GD SH Series
SH 系列 105℃
特点
◆适用于通讯设备、开关电源等电路中。
◆ 安全防爆阀设计。
SH Series 105℃
Fearures
◆ Used in communication equipments,switching power supply,etc。
◆ Safety vent construction design 。
技术要求 Specifications
项目ltem |
特性Performance Characteristics |
使用温度范围
Operating Temperature Range |
-40to+105℃ |
-25to+105℃ |
额定电压范围
Rated Voltage Range |
6.3to100VDC |
160to450VDC |
电容量范围
Capacitance Range |
0.1to15000μF |
0.47to220μF |
电容量允差
Capacitance Tolerance |
±20%(100Hz or 120Hz,+20℃) |
漏电流Leakage Current
(+20℃,最大max) |
I≤0.01CV或3(μA)额定工作电压充电1分钟后读数,取大者 I≤0.01CV or 3(μA)After1minutes,whichever is greater measured with rated working voltage applied |
I≤0.03CV+10(μA)额定工作电压充电1分钟后读数,
取大者 I≤0.03CV+10(μA)After
损耗角正切值
Dissipation Factor
(tgδ) |
工作电压WorkingVoltabe(VDC) |
6.3 |
10 |
16 |
25 |
35 |
50 |
63 |
100 |
160 |
200 |
250 |
350 |
400 |
450 |
D.F(%)最大 |
22 |
20 |
16 |
14 |
12 |
10 |
9 |
8 |
12 |
12 |
12 |
15 |
15 |
17 |
容量>1000μF时 ,每增加1000μF D.F值增加2%( 100Hz or 120Hz,+20℃)
For capacitance1000μF,Add 2%per another 1000μF (100Hz or 120Hz,+20℃) |
低温特性
Low Temperature
Characteristics
(120Hz) |
阻抗比,最大Impedance ratio ,max
工作电压Working Voltage(VDC) |
6.3 |
10 |
16 |
25 |
35 |
50 |
63 |
100 |
160 |
200 |
250 |
350 |
400 |
450 |
Z - 25℃ / Z+20 ℃ |
4 |
3 |
2 |
2 |
2 |
2 |
2 |
2 |
2 |
2 |
3 |
5 |
6 |
15 |
Z - 40℃ / Z+20 ℃ |
8 |
6 |
4 |
3 |
3 |
3 |
3 |
3 |
容量>1000μF时 ,每增加1000μF ,Z - 25℃ / Z+20 ℃值增加0.5%, Z - 40℃ / Z+20 ℃值增加1% Fpr capacitance>1000μF , and 0.5% per another 1000μF for Z-25℃/Z+20℃, add 1% per another 1000μF for Z-40℃/Z+20℃ |
负荷寿命Load Life |
试验条件 |
Test conditions |
持续时间:2000小时 |
Duration time: 2000hours |
环境温度:+105℃ |
Ambient timperature: +105℃ |
施加电压:额定工作电压(VDC) |
Applied voltage: Rated Working Voltage(DVC) |
试验后要求:室温下恢复16小时,+20℃测试 |
After test requirements: Resumde 16 hours at
normal temperature |
电容量变化:≤20%规定值 |
Capacitance change:≤20% of the initial measured value |
损耗角正切值:≤200%初始值 |
Dissipation Factor:≤200% of the initial specified value |
漏电流:≤规定值 |
Leakage Current:≤The initial specified value |
储存寿命Shelt Life |
试验条件 |
Test conditions |
持续时间:1000小时 |
Duration time: 1000hours |
环境温度:+105℃ |
Ambient temperature:+105℃ |
施加电压:无 |
Applied voltage: None |
After test requirements: Resumed 16 hours at
normal timperature |
电容量变化:≤20%规定值 |
损耗角正切值:≤200%初始值 |
漏电流:≤200%规定值 |
Leakage Current:≤200% of the initial specified value |
