产品名称: 無極性立式電解電容器
型  号: 3.3uf/50v 5x11
价  格:
NPH series Non-Polarized+105℃ wide temperature range standard无极性+105℃宽温度品
1.       适用于极性反转回路,例如:信号交连或HI-FI高级音 响设备如喇叭等。
NP series capacitors are suitable for crossover network for HI-FI  equipment’s and speakers, etc.
2.  具容量误差小,频率响应高之特质。
Have excellent frequency characteristic and small deviation of Capacitance.
Specifications
No.
Item
Performance
1
使用温度范围
Operating Temperature Range
-40℃ to +105℃
2
定格电压范围
Rated Working Voltage Range
  6.3-100V.DC
3
静电容量范围
Capacitance Tolerance
0.1-2200µF
4
静电容量容许差
±20% (at+25℃,120Hz)
5
泄漏电流
Leakage Current
I≤0.03CV or 3(µA) after five minutes
6
损失角
Dissipation Factor(tanδ) (120Hz\+25℃)
Working Voltage(v)
6.3
10
16
25
35
100
tanδ     max.
0.25
0.25
0.20
0.15
0.15
0.13
0.10
0.12
7
温度特性(at  120  Hz)
Characteristics at low temperature (stability at 120Hz)
Working Voltage (V)
6.3
10
16
25
35
100
-25℃/+20℃
4
3
2
2
2
2
2
2
-40/℃+20℃
8
6
4
4
3
3
3
3
8
高温负荷特性
High Temperature Loading
After2000 hrs. application of DC rated working voltage at +105℃.
The capacitor shall meet the following limits:
Post test requirements at + 25℃
Leakage current
≤ the Initial specified value
Capacitance change
≤±20 % of initial measured value
≤200% of initial specified value
9
高温无负荷特性
Shelf Life
After storage for 1000hrs. at+105℃ with no voltage applied.
Post test requirements at+25℃
Same limits for high temperature lading.
关 键 词: 无极性电解电容 FASTCON电容 高频低阻抗电解电容
公司名称: 深圳市华凯兴业电子有限公司
联 系 人: 譚萬忠
电  话: 0755-84673230
手  机: 13728983171
地  址: 廣東省深圳市龍崗區平湖鎮
邮  编: 518111
铝电解电容器4700UF(SH 4700UF16V 16X20)
高頻低阻抗鋁電解電容器6(680UF10V 8X9)
臥式(軸向)無極性鋁電解(6.8UF100v 6*17)
7mm高超小型无极性电解(NP 2.2UF50V 4x7)
高频低阻抗电解电容470(LEH 470UF6.3V 6.3X7)
高压卧式电解电容器(22UF450V 16X28)
大型牛角鋁電解電容器(100uf/450v 35*30)
