产品介绍: |
Technical data |
Mounting height: |
5,5 ... 15 m |
Corridor width: |
1 ... 26 m |
Average velocity: |
2.4 m/s |
Scanning angle: |
90 ° |
Laser class: |
1 |
Optical displays: |
4 x LED status displays |
Data format: |
8 data bits, no parity, 1 stop bit |
Electrical connection: |
1 x 9 pole terminal strip on internal connection board, 2 x PG-11 cable gland (for cable diameter 8 ... 10 mm) |
Housing: |
Polystyrene |
Operating voltage: |
24 V DC +/- 20% |
Enclosure rating: |
IP 40 |
Ambient operating temperature: |
0 °C ... +40 °C |
Housing colour: |
White aluminium (RAL 9006) |
Data interface: |
RS-422 |
Data transmission rate: |
19200 Bd |
Power consumption: |
Operation: 12 W (0.5 A) at 24 V DC, plus max. 0.5 A per switching output, Switching on: max. 36 W (1.5 A) at 24 V DC |
Storage temperature: |
-20 °C ... +80 °C |
Weight: |
6 kg |
Mounting system type: |
Jointed foot on the device, pipe clamping system with mounting foot, protection against dropping |
Dimensions (L x W x H): |
264,5 x 350 x 340 mm |
