产品介绍: |
- LED光源,可见红光或红外光
- 背景遮蔽功能
- 可调校检测距离
- 开关频率为1000/s或1500/s
- 输出短路保护
Model Name |
Part Number |
Dimensions (W x H x D) |
Connection type |
Sensing range min ... max |
WT9-2N130 |
1018294 |
12 x 40 x 22 mm |
Cable, 2 m |
30 ... 250 mm |
WT9-2N430 |
1018296 |
12 x 40 x 22 mm |
Connector, M12, 4-pin |
30 ... 250 mm |
WT9-2P430 |
1018295 |
12 x 40 x 22 mm |
30 ... 250 mm |
WT9-2P630 |
1019272 |
12 x 40 x 22 mm |
Cable with plug, M12, 4-pin, 120 mm |
30 ... 250 mm |
WT9-2P110 |
1018577 |
12 x 40 x 22 mm |
Cable, 2 m |
30 ... 250 mm |
WT9-2P410 |
1019668 |
12 x 40 x 22 mm |
30 ... 250 mm |
WT9-2P130 |
1018293 |
12 x 40 x 22 mm |
Cable, 2 m |
30 ... 250 mm |
WT9-2P330 |
1019026 |
12 x 40 x 22 mm |
Connector, M8, 4-pin |
30 ... 250 mm |
WT9-2P310 |
1028279 |
12 x 40 x 22 mm |
30 ... 250 mm | |
