产品名称: LE910C4-NF全新原装telit泰利特cat4 4G无线通信模块
型  号: LE910C4-NF
价  格:
Telit LE910C4-NF industrial-grade LTE Category 4 module is compliant with band-14 specifications and requirements for use in America's dedicated public safety, first responder networks. The module complies with 3GPP Release 10 and is available with optional quad-constellation GNSS capability.
  Key Benefits:
  * Band 14 (emergency responder ) support
  * Best-in-class 3GPP Rel. 10 platform
  * Easy to integrate with peripherals and actuators using USB 2.0 HS, UART and user-definable GPIOs
  * Internet friendly with integrated TCP/IP and UDP/IP stacks
  * Simple drop-in migration and technology design reuse path to 2G and 3G with any xE910 module
  * Over-the-Air firmware update
  * Embedded GNSS solution
  Telit LE910C4-NF Mini PCIe module Specs and Features:
  * LTE Cat.4 Module
  * Support 4G LTE Bands: B12, B14, B4, B2, B5, B13, B66, B71
  * Support 3G B2, B4, B5
  * Band 14 support
  * LTE FDD Cat.4, 3GPP release 10 compliant
  * Rx Diversity and MIMO DL 2x2
  * Single Rx option
  * VoLTE support
  * SMS over IMS
  * Built-in UDP/TCP/FTP/SMTP stack
  * IPv4/IPv6 stack
  * Control via AT commands according to 3GPP
  * TS 27.005, 27.007 and Telit Custom AT commands
  * SIM application Tool Kit 3GPP TS 51.014
  * OMA-DM Telit Software Management
  * Simultaneous support of GPS, Glonass, Beidou, Galileo, QZSS
  * Data rates:
  - LTE Cat. 4: Uplink up to 50 Mbps, Downlink up to 150 Mbps
  - DC-HSPA+ 42 Mbps
  * Environmental
  - Dimensions 51 x 30 x 3.2 mm
  - Temperature Range: Industrial: -40°C to +85°C
  - REACH and RoHS compliant
  * Interfaces
  - 181-pin LGA interface
  - 10 I/O ports (@1.8V) including multifunctional I/Os
  - USB 2.0 HS / HSIC
  - UART
  - SPI
  - PCM
  - 1.8 V / 3 V SIM interface
  - RF pad, RX Div. & MIMO pad
  * Approvals
  - FCC/IC, PTCRB, GCF
  - MNO: AT&T, VZW, T-Mobile
  * Electrical & Sensitivity
  - Output power
  - Class 3 (0.2 W, 23 dBm) @ LTE
  * Supply voltage range:
  - Nominal: 3.8 VDC
  - Range: 3.3 - 4.2 VDC
关 键 词: LE910C4-NF 4G模块 泰利特
公司名称: 深圳市鹏城润电子有限公司
联 系 人: 宋朋
电  话: 0755-13544155658
手  机: 13544155658
地  址: 福田区华强北商业街高科德电子市场51847房
邮  编: 518000
移远4G智能模块SC60(SC60)
有方 N720-EA C(N720-EA-04)
梦芯MXT903A MX(MXT903A MXT906A MXT909U)
移远QUECTEL SC(C200L-CE、SC200L-EM、SC200L-EU)
AG35 移远车规级4G(AG35)
泰利特Telit UE9(UE910-GL)
广和通MC116-EUL(广和通MC116-EUL MC116-NA 4G模块 内置GSNN定位功能 高通芯片组)
LC29D/LC79D移(LC29D/LC79D)
Q24PL001法国WA(Q24PL001,Q24PLUS)
LE910-NA1泰利特(LE910-NA1)
SiliconLabs (ETRX357)
