产品名称: X51N系列信号调理器(控制室用)
型  号: X51N
X51N系列信号调理器(控制室用)
Model X51N Series -- Control Room Signal Conditioning [X51N]
Signal Conditioners with In-Circuit Calibration and High Panel Density Equals Lower Costs and Easier Installation
  • RTD, T/C, mV, mA, V input transmitters, alarm trips, combination transmitter/trips and computational transmitters.
  • On-board plug-in sub-module facilitates change of range or sensor type.
  • Convenient front panel access to span, zero, and setpoint controls.
  • In-circuit calibration and input monitoring via front panel jacks,
  • without disconnecting the input or output wiring.
  • Signal to power supply isolation standard on all modules.
  • Input to output isolation on temperature transmitters.
  • Power On indicator on all modules.
  • Single and dual setpoint alarm trip and combination transmitter/alarm trips.
  • Plug and socket selection for relay operation and high or low setpoint.
  • Sensor failure detection without shutdown on RTD modules.
  • High density mechanical design, 20 modules in a standard 19 inch (48.25 cm) rack mount.
The Ronan X51N Series process signal conditioners, transmitters, alarm trips, and combination transmitter/trips, feature the most extensive selection of interface modules, providing high density packaging for the most economical price. The designs incorporate solidly based experience from the many thousands of installed and operating units, and offer superior performance based on today's technology and proven design techniques. The high density arrangement of the X51N Series, most suitable for system application in today's space-limited control rooms, is enhanced with the ultra high density combination of transmitter and alarm trip contained in the same module. These combination modules provide a unique solution to instrumentation requirements, where previously a transmitter and an alarm trip module occupied twice the space, thus providing an obvious economical advantage.
关 键 词: X51N Ronan
公司名称: 武汉海瑞特自动化工程有限公司
联 系 人: 刘先生
电  话: 027-87630899
手  机: 13971189233
地  址: 东湖新技术开发区关东园路2-2光谷国际B座
邮  编: 430000
MK-SBB-380污水(MK-SBB-380)
Herrett MK-S(MK-SBB-380)
威力巴流量计(DDM-EC1610)
AMG-MiNi660迷(AMG-MiNi660)
迷你型音叉液位开关(AMG-MiNi660)
L2000射频导纳料位开(L2000)
40-7高精密减压阀,4(40-7)
L2000射频导纳物位控(L2000)
40-2高精密减压阀,4(40-2)
550-ACD电气转换器(550-ACD)
T-10高精度减压阀(T-10)
STT150/250/3(STT150/250/350)
830 X防爆数显表 (830 X)
ST3000系列表压、差(ST3000)
SMV3000多参量流量(SMV3000)
SEM310 智能型温度(SEM310)
热式风速测量计(soft(德国softflow)
K-IP电气转换器(AB(K-IP)
FR20空气过滤调节器(FR20)
