| 产品名称: |
MARSH控制测试精密压力表
| 型 号: |
D系列控制测试精密压力表 |
| 价 格: |
| 品 牌: |
产品介绍: |
MARSH控制测试精密压力表
精度Accuracy |
ASME Grade 3A – ±0.25% of range across full scale |
表径Case Sizes |
6" (160mm) diameter |
外壳材质Case Material |
304 Stainless Steel |
安装方式Case Style |
LM–Lower Mount |
内芯材质Tube & Socket |
Copper alloy |
运动件材质Movement |
Stainless Steel |
接口Connection |
1/4 NPT through 600 psi 1/2 NPT 1000 psi & above |
测量范围Ranges |
0 to 30" Hg VAC; Compound 30" Hg to 60 psi; 15 to 10,000 psi |
刻度盘Dial Standard |
single scale psi |
刻度盘颜色Dial Color |
Black markings on white aluminum with mirror dial to avoid parallax |
指针Pointer |
Knife-edge Aluminum, black painted |
窗口Window |
Instrument Glass |
压力释放Pressure Relief |
Blowout plug |
MARSH控制测试精密压力表订货选型Part Numbers: |
尺寸 |
6" (160mm) |
连接 |
1/4 NPT |
1/2 NPT |
0 to 30" Hg VAC |
D31405 |
30" Hg VAC to 15 psi |
D31410 |
30" Hg VAC to 30 psi |
D31412 |
30" Hg VAC to 60 psi |
D31414 |
0 to 15 psi |
D31440 |
0 to 30 psi |
D31442 |
0 to 60 psi |
D31446 |
0 to 100 psi |
D31448 |
0 to 160 psi |
D31452 |
0 to 200 psi |
D31454 |
0 to 300 psi |
D31458 |
0 to 400 psi |
D31460 |
0 to 600 psi |
D31464 |
0 to 1,000 psi |
D31472 |
0 to 1,500 psi |
D31474 |
0 to 2,000 psi |
D31476 |
0 to 3,000 psi |
D31478 |
0 to 5,000 psi |
D31482 |
0 to 10,000 psi |
D31490 |
| 关 键 词: |
精密压力表 测试压力表 Marsh压力表 |
公司名称:
北京杰德莱特科技有限公司
| 联 系 人: |
王强
| 电 话: |
010-85501516
| 手 机: |
15601046548 |
| 地 址: |
北京市朝阳区朝阳路67号财满街8号楼01110室 |
| 邮 编: |
100025 |
| 主 页: |
