| 产品名称: |
MARSH 100mm充油耐震压力表
| 型 号: |
MARSH X系列充油耐震压力表 |
| 价 格: |
0.00 |
| 品 牌: |
产品介绍: |
MARSH 100mm充油耐震压力表
精度Accuracy |
ASME Grade A – ±2/1/2% (±1% of range across middle half of scale) |
表径Case Size |
100mm (3.89") diameter |
外壳材质Case Material |
304 Stainless Steel |
安装方式Case Style |
Rolled ring, hermetically sealed case CB – Center Back Mount LM – Lower Mount UC– U-Clamp Mount |
内芯材质Tube & Socket |
Copper alloy or 316 stainless steel |
运动件材质Movement |
Brass |
接口Connection |
1/4" NPT |
测量范围Ranges |
0 to 30" Hg VAC Compound 30" Hg VAC to 300 psi 15 to 10,000 psi |
刻度盘Dial Standard |
Dual scale psi & kPa |
刻度盘颜色Dial Color |
Black markings on white |
指针Pointer |
Aluminum, Black painted |
窗口Window |
Polycarbonate |
限位器Restrictor |
Glycerine - Standard |
充液材质Fill Medium |
Standard for all ranges |
排气塞Vent Plug |
Removable tip for venting |
MARSH 100mm充油耐震压力表选型Part Numbers: |
Type: 100mm Severe Service Gauge |
Internals |
Copper Alloy |
Stainless Steel |
Mounting / Case Style |
LM |
CB |
UC |
LM |
CB |
UC |
0 to 30" Hg VAC |
X32965P |
X32967P |
30" Hg VAC to 30 psi |
X32501P |
30" Hg VAC to 60 psi |
X32502P |
30" Hg VAC to 100 psi |
30" Hg VAC to 150 psi |
X32887P |
X32901P |
X32894P |
X32929P |
X32941P |
X32935P |
30" Hg VAC to 200 psi |
X32888P |
X32902P |
X32895P |
X32930P |
X32942P |
X32936P |
30" Hg VAC to 300 psi |
X32889P |
X32903P |
X32896P |
X32931P |
X32943P |
X32937P |
0 to 15 psi |
X32504P |
X32546P |
X32525P |
X32630P |
X32678P |
X32654P |
0 to 30 psi |
X32505P |
X32547P |
X32526P |
X32631P |
X32679P |
X32655P |
0 to 60 psi |
X32506P |
X32548P |
X32527P |
X32632P |
X32680P |
X32656P |
0 to 100 psi |
X32507P |
X32549P |
X32528P |
X32633P |
X32681P |
X32657P |
0 to 160 psi |
X32508P |
X32550P |
X32529P |
X32634P |
X32682P |
X32658P |
0 to 200 psi |
X32509P |
X32551P |
X32530P |
X32635P |
X32683P |
X32659P |
0 to 300 psi |
X32510P |
X32552P |
X32531P |
X32636P |
X32684P |
X32660P |
0 to 400 psi |
X32511P |
X32553P |
X32532P |
X32637P |
X32685P |
X32661P |
0 to 600 psi |
X32512P |
X32554P |
X32533P |
X32638P |
X32686P |
X32662P |
0 to 1,000 psi |
X32513P |
X32555P |
X32534P |
X32639P |
X32687P |
X32663P |
0 to 1,500 psi |
X32514P |
X32556P |
X32535P |
0 to 2,000 psi |
X32515P |
X32557P |
X32536P |
X32641P |
X32689P |
X32665P |
0 to 3,000 psi |
X32516P |
X32558P |
X32537P |
X32642P |
X32690P |
X32666P |
0 to 5,000 psi |
X32518P |
X32560P |
X32539P |
X32644P |
X32692P |
X32668P |
0 to 6,000 psi |
X32519P |
X32561P |
X32540P |
X32645P |
X32693P |
X32669P |
0 to 10,000 psi |
X32647P |
X32695P |
X32671P |
NOTE: shaded areas indicate items are available on special order, however, minimums and lead times apply. Consult factory. |
| 关 键 词: |
MARSH压力表 X系列压力表 充油耐震压力表 |
公司名称:
北京杰德莱特科技有限公司
| 联 系 人: |
王强
| 电 话: |
010-85501516
| 手 机: |
15601046548 |
| 地 址: |
北京市朝阳区朝阳路67号财满街8号楼01110室 |
| 邮 编: |
100025 |
| 主 页: |
