精度Accuracy |
± 2.5% Full Scale ASME grade B |
表径Case sizes |
1-1/2" 2" 2-1/2" 4" |
外壳材质 Case Material |
ABS (Acryl Nitril Butadien Styrol)
Black painted steel with chrome triangular bezel and U-Clamp
304 Stainless Steel |
波登管材质 Bourdon tube |
Phosphor bronze
316 Stainless steel coiled safety tube |
运动件材质 Movement |
Brass & Nylon, or All-Brass with highly polished bearing surfaces |
窗口 Lens |
Clear front Plexiglass |
接口 Connection |
1/8" NPT 1/4" NPT |
指针 Pointer |
Molded plastic
Balanced micro-adjustable aluminum. black finish |
刻度 Dial |
White background with black psi scale and red kPa scale. |
NOSHOK 100系列标准压力表选型表: 请联系本公司。 |
