精度Accuracy |
± 0.25% Full Scale ASME grade 3A |
表径Case sizes |
6" |
外壳材质 Case Material |
304 Stainless steel |
波登管材质 Bourdon tube |
Berylium copper to 1000 psi 316 SS 1500 psi to 10000 psi NI Span C 15000 psi to 20000 psi |
运动件材质 Movement |
Brass with jeweled bearings nickel-silver pinion gear and shafts |
窗口 Lens |
Instrument glass |
接口 Connection |
1/4" NPT bottom connection 1/2" NPT bottom connection for 20,000 psi |
指针 Pointer |
Adjustable knife-edge pointer |
刻度 Dial |
Aluminum, white mirrored background with black graduations |
NOSHOK 800系列精密测试压力表选型表:如有需要请联系本公司。 |
