Flowserve NT3000 电气转换器
.Valtek NT3000 是一款安装和调试都非常简单方便的坚固型 I/P 转换器。它采用镀粉的标准铝外壳,几乎不会受到恶劣工厂环境的侵蚀。NT3000 通过了 Factory Mutual、加拿大标准协会、CENELEC (ATEX) 和 SAA 的本质安全和防爆认证。出厂时已进行零和跨度校准,免除了用户的 I/P 设置工作。当然,用户也可以使用螺栓将 I/P 与现有的 Valtek Beta、Valtek XL、Valtek XL 90 或 Automax Apex 定位器连接,调整定位器的零和跨度,然后调试阀门。
Flowserve NT3000 电气转换器技术参数:
输入:4-20mA
输出:3-15psi
认证:防爆/本安,FM/CSA
电气接口:1/2“NPT
带不锈钢压力表。
Flowserve NT3000 电气转换器选型表:
系列Series/Prefix |
NT3000 Series |
3 |
3 |
通讯Communications |
4-20 mA |
0 |
0 |
特征Diagnostics |
None |
0 |
0 |
材质Material |
Aluminum |
0 |
0 |
Stainless Steel |
1 |
认证Certification |
I/P 4-20 mA EExia EExib intrinsically safe NT 3000 ATEX II 1 GD |
04 |
04 |
I/P 4-20 mA SAA Explosion Proof Ex d, Intrinically safe Ex ia Ex N , (SAA) NT3000 |
05 |
I/P 4-20 mA EExd Exp proof NT 3000 ATEX II 2 GD |
07 |
I/P 4-20 mA Exp proof/intrinsically safe NT 3000 FM/CSA |
10 |
I/P 4-20 mA General purpose NT 3000 |
14 |
压力表Gauges (qty / material / units of measure) |
(1) / Stainless steel gauges with brass fittings / psi bar kPa |
2 |
2 |
(1) / Stainless steel gauges with Stainless steel fittings / psi bar kPa |
4 |
(1) / Stainless steel gauges with brass fittings / kg cm2 psi |
6 |
(1) / Stainless steel gauges with Stainless steel fittings / kg cm2 psi |
8 |
No gauges (Stainless steel plugs) |
9 |
密封及温度
Soft Goods / Temperature |
(Standard) Buna-N, Fluorosilicone / -40° to +185°F (-40° to +85°C) |
S |
S |
Viton / -20° to +185°F (-29° to +85°C) |
V |
EPDM / -40° to +185°F (-40° to +85°C) |
E |
电气接口
Conduit Connection |
½" NPT |
N |
N |
M20 |
M |
排气Vent |
Non-Vented |
1 |
1 |
Vented |
2 |
外观喷涂Paint |
White |
W |
W |
Black |
B |
Food Grade |
F |
No paint (Stainless steel) |
S |
