产品名称: Flowserve logix3200系列数字定位器
型  号: logix3200系列数字定位器
Logix 3200IQ 利用先进的压电技术和内回路反馈提供优越的性能、控制和可靠性,同时采用紧凑、轻型和模设计最大程度地降低耗气量。Logix 3200IQ 用于采用控制阀的行业,例如油气生产和提炼、化学加工以及纸浆和造纸行业。它将继续在全球范围内的新兴市场和地区获得认可
Flowserve logix3200系列数字定位器技术参数:
电源供给Power supply
Two-wire, 4-20 mA input
通讯Communications
HART Protocol
线性度Linearity
≤0.5% full scale
迟滞Hysteresis
≤0.5% full scale
重复精度Repeatability
≤0.1% full scale
死区Deadband
≤0.1% full scale
工作温度 Operating  temperature range
Standard: -4°F to 176°F (-20°C to 80°C)
Low: -40°F to 176°F (-40°C to 80°C)
外壳Housing
Cast, powder-painted aluminum
or stainless steel
重量Weight
Aluminum: 8.5 lb. (3.9 kg)
Stainless steel: 20.5 lb. (9.3 kg)
Flowserve logix3200系列数字定位器选型表:
Selection
Code
Example
3
3
协议Protocol
HART
2
2
特征Diagnostics
Standard
0
1
Advanced
1
材质Material
Aluminum, White Paint (Valtek)
0
0
Stainless Steel, No Paint (Valtek)
1
Aluminum, Black Paint (Automax)
2
Aluminum, Food-Grade White Paint (Automax)
3
Aluminum, Black Paint (Accord)
4
Aluminum, Food-Grade White Paint (Accord)
5
设计版本
Design Version
IQ
IQ
认证Certifications
Explosionproof EEx d IIB + H2, ATEX II 2 G (CENELEC)
07
10
Explosionproof Class I, Div 1, Groups B, C, D Intrinsically Safe Class I,
Div 1, Groups A through G (FM, CSA) FM Nonincendive. CSA Class I,
Div 2, Class I, Zone 1, Group IIB + H2 and Exia Class 1, Zone 0,
Group IIC (CSA Only)
10
General Purpose
14
Intrinsically Safe EEx ia IIC T4, Standard Temp: -40°F (-40°C) ≤ Ta ≤ 176°F (80°C)/131°F (55°C), ATEX II 1 G (CENELEC)
15
IECEx Ex d IIB + H2
16
轴Shaft
DD 316 Stainless Steel Shaft (Valtek Standard)
D6
D6
NAMUR 316 Stainless Steel (VDI/VDE 3845)
N6
电气接口Conduit Connections
1/2" NPT
E
E
M20
M
方式Action
Four-way (Double-Acting)
04
04
Three-way (Single-Acting)
03
Four-way Vented (Double-Acting)
4V
Three-way Vented (Single-Acting)
3V
温度Temperature
Operating Temperature (-40°F to 176°F; -40°C to 80°C)
40
40
压力表Gauges
Gauges (Valtek standard)
OG
OG
Stainless Steel Gauges
OS
Stainless Steel with Brass Internals (kg/cm2)
KG
Stainless Steel with Stainless Steel Internals (kg/cm2)
KS
No Gauges
OU
特殊选项
Special Options
4-20 mA Position Feedback
OF
OF
No Specials
OO
关 键 词: Flowserve logix3200系 数字定位器
公司名称: 北京杰德莱特科技有限公司
联 系 人: 王强
电  话: 010-85501516
手  机: 15601046548
地  址: 北京市朝阳区朝阳路67号财满街8号楼01110室
邮  编: 100025
TESCOM高压调压阀-(44-42系列)
TESCOM液压调压阀-(54-28系列)
TESCOM装备气室调压(26-12系列)
TESCOM背压调压阀-(26-25系列)
TESCOM背压调压阀4(44-23系列)
TESCOM高压调压阀-(BB-1系列)
TESCOM高压调压阀-(44-13系列)
TESCOM低压调压阀-(26-16系列)
美国 BLUE WHIT(蹼轮式流量计 F-2000系列)
TESCOM高压调压阀-(44-11系列)
TESCOM高压调压阀-(44-18系列)
微型流量比例阀(EVP-10-0925)
ASCO 板接式电磁阀 (SCG551A001ms)
美国 BLUE WHIT(蹼轮式流量计 F-1000系列)
GLE系列超微型电磁阀(GLE系列)
GLD-Cryo系列高压(GLD-Cryo系列)
GLM系列超微型电磁阀(GLM系列)
GL110,120系列电(GL110,120系列)
BELLOFRAM T1(T1000 电气转换器)
Valtek Beta
