NORGREN R27精密调压阀
Norgren R27 精密调压阀是高精度手动调压阀,利用控制控代替弹簧来调节压力,从而提高了对任何变化灵敏度,消除了弹簧的滞环;有极好的长期稳定性,有手轮式、杠杆式、活塞式和先导式控制。
Norgren R27 精密调压阀技术参数:
介质 |
经5чm过滤的无油干空气 |
供气压力 |
最小出口压力0.2bar,最大10 bar |
流量 |
可达300l/min |
滞环和重复性 |
设置于中间位置时,小于0.005% |
壳体材质 |
钝化锌压模 |
内弹簧材质 |
中碳钢 |
弹性材料 |
增强尼龙 |
接口和底板螺丝材质 |
堵镍黄铜 |
Norgren R27 精密调压阀选型表:
描述Description |
型号Model |
控制类型Control Type |
输出Output Range |
Standard regulator |
R27-200-RNCG |
Handwheel 2.5–3 turns |
0.14–2.0 bar |
R27-200-RNFG |
0.14–4.0 bar |
R27-200-RNLG |
0.14–8.0 bar |
Lever operated regulator |
R27-230-RNCG |
Lever control 125° Rotation |
0.14–2.0 bar |
R27-230-RNFG |
0.14–4.0 bar |
R27-230-RNLG |
0.14–8.0 bar |
Plunger operated regulator |
R27-232-RNFG |
Plunger travel 1.65mm |
0.14–4.0 bar |
R27-232-RNLG |
0.14–8.0 bar |
Pilot operated relay |
R27-234-RNCG |
Pilot pressure signal |
0.14–8.0 bar |
Pilot operated relay with manual bias |
R27-236-RNXG |
Pilot pressure signal. Handwheel controlled bias |
0.14–8.0 bar Bias of up to 2 bar |
